Author Topic: I'd like to make a point  (Read 3037 times)
« on: December 15, 2008, 08:56:41 PM »
In short, the function uses grvecs to draw a multi colored sphere at the specified point, using the radius and colors1 and 2 if supplied. The radius value, if provided, is treated like the pdsize variable. The colors are treated per the grvecs function. If passed nils for radius, color1 and color2 it resorts to defaults, which are 1/100 screen size, red and green respectively.
Why: I needed visual confirmation of points generated by a program I was writing, but I didn't want to create any temporary entities. So I quickly bashed this out (hasn't been optimized yet).
Quick examples:
      ;; default 1/100 screensize, default red, default green
      (grpoint (getpoint "Pick a point: ") nil nil nil)
      ;; default 1/100 screensize, yellow, blue
      (grpoint (getpoint "Pick a point: ") nil 2 5)
      ;; 1/200 screensize, yellow, yellow
      (grpoint (getpoint "Pick a point: ") -0.5 2 2)
(defun GrPoint ( point radius color1 color2 / i j k angles )
    (setq radius
        (if (numberp radius)
            (if (minusp radius)
                (* (/ (abs radius) 100.0) (getvar "viewsize"))
                radius
            (* 0.01 (getvar "viewsize"))
    (setq
        color1 (if (eq 'int (type color1)) color1 1)
        color2 (if (eq 'int (type color2)) color2 3)
        j      0.05
        k      (/ j 2.0)
        i      (- j)
    (repeat (fix (/ 1.0 j))
        (setq angles
            (cons
                (+ k (* 0.5 pi (setq i (+ i j))))
                angles
    (mapcar
       '(lambda ( args / point color start_angle angles )
            (setq
                point       (car args)
                color       (cadr args)
                start_angle (caddr args)
                angles      (cadddr args)
            (grvecs
                (apply 'append
                    (mapcar
                       '(lambda ( incr_angle )
                            (list
                                color
                                point
                                (polar
                                    point
                                    (+ start_angle incr_angle)
                                    radius
                        (cadddr args)
        (list
            (list point color1 (* 0.0 pi) angles)
            (list point color2 (* 0.5 pi) angles)
            (list point color1 (* 1.0 pi) angles)
            (list point color2 (* 1.5 pi) angles)
    point ;; return the original point to the caller
Sorry, don't have time to document this better or clean up the local vars. Will do down the road when I've more time.
Later dudes.
Slim©
  • The Dude Abides...
Re: I'd like to make a point
« Reply #1 on: December 15, 2008, 09:13:08 PM »
Nice job!!! Did something similar a few years ago, but this is better.
I drink beer and I know things....
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #2 on: December 15, 2008, 11:15:10 PM »
Nicely bashed together Michael.
Called Kerry in my other life
I live at UTC + 13.00
« Reply #3 on: December 16, 2008, 01:11:34 AM »
Thanks guys, dirty but did the job.
« Reply #4 on: December 16, 2008, 10:21:42 AM »
I'm hope someday to write "dirty" code like you  :-P
« Reply #5 on: December 16, 2008, 10:36:57 AM »
{shrug} Thanks Ron, I've got nothing on you. :)
Except maybe 50 lbs. :(
Maverick®
« Reply #6 on: December 17, 2008, 12:09:45 AM »
Put your head on his shoulder?  :-D
« Reply #7 on: December 17, 2008, 09:01:54 AM »
would take a LOT of tequila to get me to that point
yes, I know what you meant: I can still get thru the door :P
