Author Topic: Wblock with ObjectDBX and Visual Lisp  (Read 5149 times)
mmalbr
« on: December 12, 2008, 11:22:53 AM »
What's wrong in the code below?
Should export a new drawing for a block contained in another design without opening it
(setq
*acad* (vlax-get-acad-object)
doc (vla-get-activedocument *acad*)
desenho "C:\\Arquivos de programas\\AutoCAD 2007\\support\\db_samp.dwg"
(setq oDBX (vla-GetInterfaceObject *acad* "ObjectDBX.AxDbDocument.17"))
(vla-open oDBX desenho)
(vlax-for layout (vla-get-layouts oDBX)
(vlax-for blk (vla-get-block layout)
(if (and
(= (vla-get-objectname blk) "AcDbBlockReference")
(= (strcase (vla-get-name blk)) "CHAIR7")
(setq nomes_lst (cons blk nomes_lst))
nomes_lst
(setq SAwallobj (vlax-make-safearray vlax-vbObject '(0 . 0)))
(vlax-safearray-fill SAwallobj (car nomes_lst)) ; error here
(vla-wblock oDBX "c:/bloco.dwg" SAwallobj) ; and error here too
Marcos Mendes
Visit my site:
http://www.autolisp.com.br/
Re: Wblock with ObjectDBX and Visual Lisp
« Reply #1 on: December 12, 2008, 11:30:09 AM »
It looks like vla-wblock is looking for a selection set rather than a safearray
mmalbr
« Reply #2 on: December 12, 2008, 11:47:08 AM »
SAwallobj is SAFEARRAY, but is not it working!
« Reply #3 on: December 12, 2008, 12:03:12 PM »
Welcome to the Swamp. :-)
« Reply #4 on: December 12, 2008, 12:16:57 PM »
Hi Marcos. Welcome to the Swamp!
As Ronjonp noted, you are passing an array to the WBLOCK method which is expecting a SelectionSet. Since you cannot create or use selection sets in an ObjectDBX document wou will need to do this another way. Try creating the new drawing, then use the CopyObjects (which CAN use the array you created) method to get the entities into that new drawing
efernal
« Reply #5 on: December 12, 2008, 12:26:02 PM »
ei, marcos, em menos de uma hora você já obteve 4 respostas...
aqui é o lugar, cara...
abs...
e.fernal
e.fernal
mmalbr
« Reply #6 on: December 12, 2008, 01:02:37 PM »
Pois é ... gostei daqui!
valeu mesmo!
« Reply #7 on: December 12, 2008, 01:06:50 PM »
See if this help you out some....no error checking included.
(defun copytocurrentdwg (copydoc blkname / *acad* doc objlst odbx)
  (setq *acad* (vlax-get-acad-object)
  (vl-catch-all-apply 'vla-open (list odbx copydoc))
      (if (and
    (= (strcase (vla-get-name blk)) (strcase blkname))
(setq objlst (cons blk objlst))
  (vla-copyobjects
    odbx
vlax-vbobject
(cons 0 (1- (length objlst)))
      objlst
    (vla-get-modelspace
  (vla-saveas odbx (vla-get-name odbx))
  (vlax-release-object odbx)
;;Lets run it (this copies to the current open drawing)
(copytocurrentdwg
  "CHAIR7"
« Last Edit: December 12, 2008, 03:21:41 PM by ronjonp »
Spike Wilbury
« Reply #8 on: December 12, 2008, 01:08:48 PM »
and for those of us, that do not speak Portuguese...
I think Marcos, is saying:
In less than an hour, I got four answers, I like this place...
That's why I like here!!!
It Worth's !
mmalbr
« Reply #9 on: December 12, 2008, 01:09:30 PM »
Thanks .. I will try this way!
mmalbr
« Reply #10 on: December 12, 2008, 01:20:05 PM »
