Author Topic: Another selection method question  (Read 4769 times)
Re: Another selection method question
« Reply #15 on: December 12, 2008, 02:51:07 PM »
You having coding withdrawal? :lmao:
Only a little.  Don't tell anyone though.  ;-)
Nice code Tim. 8-)
Thanks Alan.  Might be slow if a lot of blocks defined in the drawing though, but was fun to write.  You also have a nice code there buddy.
All we need to do now is add attributes in the string match. :evil:
Now you are just talking crazy.  To much checking on that one.   :-)
Depends if you want to just check the definition and default values, or check just constant attributes, or check the inserted blocks to see if the attributes have values that match the string.
« Reply #16 on: December 12, 2008, 03:01:21 PM »
Oh shoot, forgot about the block being different from the INSERT for attribute values.  :-(
