OK CAB,
Here it is:
I did try the lisp routine above, it is real nice but this very simple macro will prompt you to pick your object, you pick your viewport, it copies it, it then tiles to model space and asks you for an insertion point, you can then pick a point, it scales the viewport up (in this case by 96 because our plot scale will be 1/8"=1') it makes, the current layer defpoints, it then pastes the viewport as a block, then layer 0 is made current. From there you can copy it around in model space. So, by putting the scale portion into the macro, we now have an overall limits that we can draw within in Model space for our viewport that we will plot from.
Now, if there was a way to make the viewport a polyline instead of a block in Model Space, I would be real happy.
^C^Ccopyclip;\;(setvar "tilemode" 1);-layer;s;defpoints;;pasteblock;s;96;\(setvar 'clayer "0");
