Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
AutoLISP (Vanilla / Visual)
Visual DCL Programming
ObjectDCL
Topic:
puase autolisp for object dcl dialog box?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: puase autolisp for object dcl dialog box? (Read 8686 times)
Bob Q
Guest
on:
December 06, 2008, 01:47:13 PM »
I have a routine that cycles through some stuff, and calls an object dcl dialog box....
But the routine keeps running. Is there any way to stop the routine?
Thank you!
Logged
Seagull
Have thousands of dwgs to process? Contact me.
WWW
Re: puase autolisp for object dcl dialog box?
Reply #1 on:
December 06, 2008, 06:02:10 PM »
Without seeing the code or a more lucid description of the mechanics / work flow of the program it's difficult to suggest anything beyond:
Logged
cadanalyst@gmail.com
http://cadanalyst.slack.com
http://linkedin.com/in/cadanalyst
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Reply #2 on:
December 06, 2008, 06:18:35 PM »
Bob,
Is that ObjectDCL or OpenDCL ? ... 2 different beasts
Is the dialog Modal or Modeless ?
and what Michael indicated is important to a resolution ...
Logged
Print
Pages: [
1
Go Up
« previous
next »
Code Red
ObjectDCL
Topic:
