Author Topic: ( Challenge ) How fast can you convert these?  (Read 27192 times)
Matt__W
  • I like my water diluted.
Re: ( Challenge ) How fast can you convert these?
« Reply #15 on: December 05, 2008, 11:11:36 AM »
Hey Matt this is a LISP forum.
 :evil:
I know.  Just offering up an alternative.
Autodesk Expert Elite
« Reply #16 on: December 05, 2008, 11:14:09 AM »
another way.. not fast though
(defun c:doit ( /  activedocument e iacadapplication modelspace)
  (setq IAcadApplication (vlax-get-acad-object)
ActiveDocument (vla-get-ActiveDocument IAcadApplication)
ModelSpace (vla-get-ModelSpace ActiveDocument)
  (vlax-for e ModelSpace
     (vla-Addcircle ModelSpace (vla-get-Coordinates e) 15)
       (vla-Erase e))
« Reply #17 on: December 05, 2008, 11:17:52 AM »
Daniel that is basically the same as Matts code, but offers more overhead due to the interpretive nature of lisp.
« Reply #18 on: December 05, 2008, 11:18:29 AM »
correct.
« Reply #19 on: December 05, 2008, 11:28:15 AM »
(defun c:test (/ *time* n ss)
  (setq *time* (getvar 'millisecs)
ss     (ssget "_x" '((0 . "POINT")))
n      -1
  (repeat (sslength ss)
    (entmakex
      (list '(0 . "CIRCLE")
    '(62 . 1)
    (cons 10
  (cdr (assoc 10 (entget (ssname ss (setq n (1+ n))))))
    '(40 . 1.0)
  (princ
    (strcat "\n < Elapsed time: "
    (rtos (/ (- (getvar 'millisecs) *time*) 1000.0) 2 6)
    " seconds. > "
Why this --
    '(62 . 1)
    (cons 10
    '(40 . 1.0)
When you could do this --
    '(62 . 1)
    '(40 . 1.0)
« Reply #20 on: December 05, 2008, 11:31:56 AM »
You are correct MP...too much coffee this morning   :-)
« Reply #21 on: December 05, 2008, 11:34:39 AM »
That never happens to me. :whistle:
:D
VovKa
  • Ukraine
« Reply #22 on: December 05, 2008, 11:48:51 AM »
well, it's slower but works more like 'convert', preserving layer and color and maybe smth else :)
(defun c:test3 (/ ss *time* n EntName)
n      -1
  (while (setq EntName (ssname ss (setq n (1+ n))))
    (entmakex
      (subst '(40 . 1.0)
     '(50 . 0.0)
     (subst '(0 . "CIRCLE") '(0 . "POINT") (entget EntName))
;;;    (entdel EntName)
  (princ
    " seconds. > "
Spike Wilbury
« Reply #23 on: December 05, 2008, 12:58:58 PM »
have been a while.... don't know if say something, but was able to play with very simple coding, and doing some minor changes to the code (ok no erase of the points so, no idea if this counts, but was fun)
;;  < Elapsed time: 1.703000 seconds. >
;;  < Elapsed time: 2.454000 seconds. >
;;;(defun C:TST  (/ ss i pt)
;;;  (setq *time* (getvar 'millisecs))
;;;  (if (setq ss (ssget "x" '((0 . "point"))))
;;;    (progn
;;;      (setq i 0)
;;;      (while (< i  (sslength ss))
;;; (setq pt (cdr (assoc 10 (entget (ssname ss i)))))
;;; (entmake
;;;   (list '(0 . "CIRCLE")
;;; '(100 . "AcDbEntity")
;;; '(67 . 0)
;;; '(410 . "Model")
;;; '(8 . "0")
;;; '(100 . "AcDbCircle")
;;; (cons 10 pt)
;;; '(40 . 1.0)
;;; '(210 0.0 0.0 1.0)))
;;; (setq i (1+ i))
;;;  (princ
;;;    (strcat "\n < Elapsed time: "
;;;     (rtos (/ (- (getvar 'millisecs) *time*) 1000.0) 2 6)
;;;     " seconds. > "
;;;  (princ)
;; < Elapsed time: 2.016000 seconds. >
;;;    (progn
;;;      (setq i 0)
;;; (entmake
;;; ;;'(100 . "AcDbEntity")
;;; ;;'(67 . 0)
;;; ;;'(410 . "Model")
;;; ;;'(8 . "0")
;;; (cons 10 pt)
;;; '(40 . 1.0)
;;; ;;'(210 0.0 0.0 1.0)
;;; (setq i (1+ i))
;;;  (princ
;;;     " seconds. > "
;;;  (princ)
;;  < Elapsed time: 1.938000 seconds. >
;;;    (progn
;;;      (setq i 0)
;;; (entmakex
;;; (cons 10 pt)
;;; '(40 . 1.0)
;;; (setq i (1+ i))
;;;  (princ
;;;     " seconds. > "
;;;  (princ)
;;  < Elapsed time: 1.890000 seconds. >
;;;    (progn
;;;      (setq i 0)
;;;      (setq num (sslength ss))
;;;      (while (< i num) ;;(< i  (sslength ss))
;;; (entmakex
;;; (cons 10 pt)
;;; '(40 . 1.0)
;;; (setq i (1+ i))
;;;  (princ
;;;     " seconds. > "
;;;  (princ)
;;  < Elapsed time: 1.953000 seconds. >
;;;    (progn
;;;      (setq i 0)
;;; (setq ename (ssname ss i))
;;; (setq lst (entget ename))
;;; (setq pt (cdr (assoc 10 lst)))
;;; (entmakex
;;; (cons 10 pt)
;;; '(40 . 1.0)
;;; (setq i (1+ i))
;;;  (princ
;;;     " seconds. > "
;;;  (princ)
;;  < Elapsed time: 1.860000 seconds. >
;;;    (progn
;;;      (setq i 0)
;;;      (repeat num
;;; (entmakex
;;; (cons 10 pt)
;;; '(40 . 1.0)
;;; (setq i (1+ i))
;;;  (princ
;;;     " seconds. > "
;;;  (princ)
;;  < Elapsed time: 1.859000 seconds. >
;;;    (progn
;;;      (setq i 0)
;;;      (repeat num
;;; ;;(setq pt (cdr (assoc 10 (entget (ssname ss i)))))
;;; (entmakex
;;; (cons 10 (cdr (assoc 10 (entget (ssname ss i)))))
;;; '(40 . 1.0)
;;; (setq i (1+ i))
;;;  (princ
;;;     " seconds. > "
;;;  (princ)
;;  < Elapsed time: 1.765000 seconds. >
;;;    (progn
;;;      (setq i 0)
;;;      (repeat num
;;; (entmakex
;;;   (list (cons 0 "CIRCLE")
;;; (cons 100 "AcDbCircle")
;;; (cons 40 1.0)
;;; (setq i (1+ i))
;;;  (princ
;;;     " seconds. > "
;;;  (princ)
      (setq i -1)
      (repeat num
(entmakex
(cons 10 (cdr (assoc 10 (entget (ssname ss (setq i (1+ i)))))))
(cons 40 1.0)))
  (princ
    " seconds. > "
;;  < Elapsed time: 1.734000 seconds. >
;;;    (progn
;;;      (setq i -1 num (sslength ss))
;;;      (repeat num
;;; (entmakex
;;; (cons 10 (cdr (assoc 10 (entget (ssname ss (setq i (1+ i)))))))
;;; (cons 40 1.0)
;;;  (princ
;;;     " seconds. > "
;;;  (princ)
« Reply #24 on: December 05, 2008, 01:29:49 PM »
 :evil:
 :wink:
Command: doit
Total running time: 0.28 seconds
  typedef AcDbObjectPointer<AcDbPoint> AcDbPointPointer;
  typedef AcDbObjectPointer<AcDbCircle> AcDbCirclePointer;
  static void CRPDArxConvert_doit(void)
    CLapseTime ltTotal;
    Acad::ErrorStatus es;
    long ssLength = 0;
    ads_name sel;
    AcDbObjectIdArray ids;
    resbuf *rbFilter = acutBuildList(RTDXF0, _T("POINT"), RTNONE);
    TCHAR* mode = _T("X");
    if (acedSSGet(mode, NULL, NULL, rbFilter, sel) != RTNORM)
      acutRelRb(rbFilter);
      return;
    if(acedSSLength(sel, &ssLength) != RTNORM || ssLength == 0)
      acedSSFree(sel);
      return;
    if(acedGetCurrentSelectionSet(ids) != Acad::eOk)
      acedSSFree(sel);
      return;
    AcDbDatabase* pDb = acdbHostApplicationServices()->workingDatabase();
    AcDbBlockTableRecordPointer pBTR(pDb->currentSpaceId(), AcDb::kForWrite); //<<<<<
    for(int i = 0 ; i < ids.length(); i++)
      AcDbPointPointer smartPointer(ids[i],AcDb::kForRead);
      if(smartPointer.openStatus() == Acad::eOk)
        AcDbCirclePointer pCircle;
        if(pCircle.create() == Acad::eOk)
          pCircle->setRadius(15.0);
          pCircle->setCenter( smartPointer->position());
          pBTR->appendAcDbEntity(pCircle);
          smartPointer->upgradeOpen();
          smartPointer->erase();
    acedSSFree(sel);
    acutPrintf(_T("\nTotal running time: %.4f seconds"), ltTotal.LapseTimeSeconds());
« Last Edit: December 05, 2008, 01:45:14 PM by Daniel »
Matt__W
« Reply #25 on: December 05, 2008, 01:31:23 PM »
 :evil:
 :wink:
Command: doit
Oooooohhh... Looks like you win!
Spike Wilbury
« Reply #26 on: December 05, 2008, 01:35:08 PM »
    acedSSFree(sel);
    acutPrintf(_T("\nTotal running time: %.2f seconds"), ltTotal.LapseTimeSeconds());
that's not fair.... for the lisp world.....
ok then, how about a version using a point container iterator...  eh...... and see if lower the time :)
I mean something like:
AcDbDatabase* pDb = curDoc()->database();
AcDbBlockTableRecordPointer modelSpace(ACDB_MODEL_SPACE, pDb, AcDb::kForWrite); // and do another for paper_space
if(modelSpace.openStatus() != Acad::eOk) return;
AcDbBlockTableRecordIterator* pIterator = NULL;
modelSpace->newIterator(pIterator);
for (pIterator->start(); !pIterator->done(); pIterator->step())
AcDbObjectId objId;
pIterator->getEntityId(objId);
AcDbObjectPointer<AcDbPoint> pointObj(objId, AcDb::kForRead); // open for what?
if (pointObj.openStatus() == Acad::eOk)
delete pIterator;
« Last Edit: December 05, 2008, 01:44:46 PM by Luis »
« Reply #27 on: December 05, 2008, 01:57:54 PM »
Command: doit
Total running time: 0.2810 seconds
Command: test
Total running time: 0.2180 seconds
  static void CRPDArxConvert_test(void)
    CLapseTime ltTotal;
    AcDbObjectId objId;
    pBTR->newIterator(pIterator);
      AcDbObjectPointer<AcDbPoint> smartPointer(objId, AcDb::kForRead);
      if (smartPointer.openStatus() == Acad::eOk)
    delete pIterator;
Spike Wilbury
« Reply #28 on: December 05, 2008, 02:31:18 PM »
Command: test
Good,
Now wait to see the C# (.NET) version..... (hope someone post a sample too).... :)
Swift
« Reply #29 on: December 05, 2008, 03:14:37 PM »
Off topic, but where did "CLapseTime" come from?
