Author Topic: 'cal  (Read 5391 times)
Big G
'cal
« on: December 04, 2008, 07:08:12 PM »
Ive always had a problem with the transparent calculator in cad and wondering if im the only one....
Command: l
LINE Specify first point:
Specify next point or [Undo]: 'cal
>>>> Expression: 500-200
Error:
Numeric overflow
>>>> Expression: *Cancel*
Resuming LINE command.
it always works on the second try...but the first try 99% of the time gets a numeric overflow...does anyone else get this error?...
perhaps i should ask, does anyone else even use this function?
I thought i seen the light at the end of the tunnel. But it was just someone with a torch bringing me more work.
"You have to accept that somedays youre the pigeon and  somedays youre the statue"
CADaver
Re: 'cal
« Reply #1 on: December 04, 2008, 07:50:11 PM »
Command: l
>>>> Expression: 500-200
Error:
Numeric overflow
What are you trying to do?  seems to work for me, but the syntax seems a bit meaningless.
Big G
Re: 'cal
« Reply #2 on: December 04, 2008, 07:58:11 PM »
nothing in particular this time, but generally when im trying to use the transp. cal. i always seem to get the error message, just upgraded to c3d 09 and curious as to why im getting the same message as before.....
i ususally use it for drawing pipe lengths from engineers RL's, so draw a line between 2 RL's say of 49.124 and 46.247 (for instance)
Command: l
Specify next point or [Undo]:  <Ortho on> 'cal
>>>> Expression: 49.124-46.247
Error:
Numeric overflow
Specify next point or [Undo]: 2.877
et voila second time it gives me the answer to the difference between the 2 RL's.....
not really that much of a hassle, just curious if anyone else was getting this and found out what it was.
CADaver
Re: 'cal
« Reply #3 on: December 04, 2008, 08:01:21 PM »
May be a load issue.  The app isn't loaded until your first attempt and it can't be loaded transparently.  Try executing a cal function at the command line non-transparently.
Big G
Re: 'cal
« Reply #4 on: December 04, 2008, 08:14:19 PM »
strange that.....
seems to load fine from the cmd line each time.....but transparently it has a problem
Command: l
>>>> Expression: 500-300
Error:
Numeric overflow
>>>> Expression: 500-300
Specify next point or [Undo]: 200
Command: cal
>> Expression: 500-300
200
CADaver
Re: 'cal
« Reply #5 on: December 05, 2008, 01:34:44 AM »
strange that.....
Command: l
>>>> Expression: 500-300
Error:
Numeric overflow
>>>> Expression: 500-300
Command: cal
>> Expression: 500-300
200
It never has loaded transparently and was so stated in the R14 documentation.
Re: 'cal
« Reply #6 on: December 05, 2008, 05:06:38 AM »
Have you tried adding something like this to your ACAD.mnl or to one of the auto-loaded files. ... just to make sure it is preloaded ..
(if (not (member "geomcal.arx"(arx)))(arxload "GEOMCAL") )
Hedgehog
Re: 'cal
« Reply #7 on: December 05, 2008, 05:46:50 AM »
Tested it in MEP 2009 & it works transparently 1st time all the time... I never have used it tho'.
TimSpangler
  • CAD Naked!!
Re: 'cal
« Reply #8 on: December 05, 2008, 07:09:03 AM »
i always use a space between the numbers ie
500 - 200
Maybe???
ACA 2015 - Windows 7 Pro
Re: 'cal
« Reply #9 on: December 05, 2008, 08:34:02 AM »
You're not alone, I've had this problem with both C3D '08 & '09.
Re: 'cal
« Reply #10 on: December 05, 2008, 09:44:18 AM »
the thing flat our wont do high order integers, and has been broken for years
Command:
Command: 'cal
>> Expression: 25*189045
4726125
Command:
CAL >> Expression: 45/483729282820
Error:
Integer numbers must be between 2147483647 and -2147483648
CADaver
Re: 'cal
« Reply #11 on: December 05, 2008, 10:19:46 PM »
Its an issue with intergers in a digital environment, has been so since we started using binary computing.
Bob Wahr
Re: 'cal
« Reply #12 on: December 05, 2008, 11:18:17 PM »
I'm guessing something with C3D is interfering based on the response you've gotten.  I use the command occasionally and have never had it do that to me.
CADaver
Re: 'cal
« Reply #13 on: December 05, 2008, 11:21:31 PM »
I've always used a function similar to the one Kerry posted to make sure the GEOMCAL is always loaded and have no issues with transparent cal functions.
Re: 'cal
« Reply #14 on: December 08, 2008, 07:47:46 PM »
Funny that you apologize for autodesk's failing here; yet one can enter the SAME values in the windows calculator and it will return a valid answer. So it's really an issue with autodesk's programming and not integers, and or binary functionality as you are suggesting.
