Author Topic: Hatch boundaries too general  (Read 4150 times)
whdjr
« on: December 03, 2008, 09:34:38 AM »
I have a rather large floor plan that i need to hatch a border around.  The edge of the floor plan is rather intricate but all my objects are closed plines.  When I hatch I use the 'pick point' and 'retain boundary'.  My problems are the hatches are 'generalizing' some of my intricate corners and not going all the way in to the plines.  Is there a setting I may have changed that I didn't know about cause I don't think this has happened before?
In the picture below the blue line is supposed to mimic the yellow line.
Bob Garner
Re: Hatch boundaries too general
« Reply #1 on: December 03, 2008, 10:15:34 AM »
I've had this problem too.  I didn't find a "cure" but as a workaround, I had to completely move the line defining my hatch boundary away from the drawing, hatch it, then move the hatch over to the drawing.
Not a right way, but it worked.
whdjr
« Reply #2 on: December 03, 2008, 10:45:03 AM »
The thing is, I only have the boundary plines.  Everything else is turned off so it doesn't interfere with the hatch.
New Shooz
« Reply #3 on: December 03, 2008, 10:46:12 AM »
Did you try creating a separate boundary, prior to hatching ?
Matt__W
  • I like my water diluted.
« Reply #4 on: December 03, 2008, 10:46:32 AM »
When I hatch I use the 'pick point'...
Have you tried SELECT OBJECTS?  What kind of results do you end up with?
Autodesk Expert Elite
Spike Wilbury
« Reply #5 on: December 03, 2008, 10:52:26 AM »
How about a copy of that dwg - to play ?
whdjr
« Reply #6 on: December 03, 2008, 10:53:39 AM »
The way my building is setup it is sprawled out very large and is not very probable to 'select objects'.  I have a bunch of closed plines and some more closed plines within those (kind of like an outline of a building).
whdjr
« Reply #7 on: December 03, 2008, 11:09:21 AM »
Here is my dwg.
Spike Wilbury
« Reply #8 on: December 03, 2008, 11:17:27 AM »
It works here... does not do what you have on that image....
Using AutoCAD 2007
- Island detection - on
- Island display - normal
- Tolerance - 0"
Notsober
« Reply #9 on: December 03, 2008, 11:18:57 AM »
this is exactly what I do when hatches aren't cooperating... works like a charm, move on.
whdjr
« Reply #10 on: December 03, 2008, 12:44:20 PM »
So the answer is , No, there isn't a setting somewhere.  So why does it do this?  It hasn't done this before.
« Reply #11 on: December 03, 2008, 12:59:42 PM »
What I have done in the past is to add hidden lines to break up the hatch area so you can zoom in.
Zooming in will pick up the hatch areas missed.
whdjr
« Reply #12 on: December 03, 2008, 01:45:22 PM »
Yeah, I know this will work I just didn't want to have too.
