All,
I found this code on the net to delete files and folders and modified it a bit to suit my needs. My question is, how can I turn it into a function that I can feed it a path and tell it how deep to delete the folders?
When I try to feed fldname a path i get an error "Expected literal constant"
Function deletefilesandfolders (foldername, deep)
const fldname = foldername
If UBound(Split (folder.path, "\")) > deep Then
End Function
deletefilesandfolders ("C:\Documents and Settings\%username%\Desktop\testdel2", 5)
const fldname = "D:\Garbage"
set fso = createobject("scripting.filesystemobject")
set fldr = fso.getfolder(fldname)
recurse fldr
sub recurse(byref fldr)
dim subfolders,files,folder,file
set subfolders = fldr.subfolders
set files = fldr.files
for each file in files
on error resume next
file.Delete
next
for each folder in subfolders
recurse folder
If UBound(Split (folder.path, "\")) > 2 Then
folder.Delete
End If
next
set subfolders = nothing
set files = nothing
end Sub
