Up until R13, you could convert a standard INSERT into a MINSERT with (entmod) on groups 70, 71, 44, 45. With the addition of group 100 codes all of that changed.
Today a MINSERT cannot be edited back into a single INSERT without a little lisp.
;;;CONVERT ( EXPLODE ) MINSERTS INTO SINGLE INSERTS
;;;05-05-2004 ADD XDATA & ATTRIBS ADDED
;;;05-07-2004 CLEANUP
;;;05-08-2004 PRESET DEFAULTS
;;;05-09-2004 FDI GLOBAL ENAME PASSING
(defun c:exmins (/ def ss en ed fe fl ml an ad al)
(setq def '(("CECOLOR" . "BYLAYER")
("CELTYPE" . "BYLAYER")
("THICKNESS" . 0)
("CELTSCALE" . 1)))
(foreach v def
(if (getvar (car v))
(setvar (car v) (cdr v))))
(not
(and fdi_global_en
(= (type fdi_global_en) 'ENAME)
(entget fdi_global_en)
(= "INSERT" (cdr (assoc 0 (entget fdi_global_en))))
(setq en fdi_global_en)))
(while (or (not ss)
(> (sslength ss) 1))
(princ "\nSelect A MINSERT To Convert: ")
(setq ss (ssget (list (cons 0 "INSERT")))))
(setq en (ssname ss 0))))
(setq ed (entget en '("*")))
(setq fl '(0 1 2 6 7 8 10 11 39 40 41 42 43 44 45 50 51 62 66 67 70 71 72 73 74 210 -3))
(foreach g fl
(set (read (strcat "g" (itoa g)))
(cdr (assoc g ed)))
(and (assoc g ed)
(not (member g '(-3 44 45 70 71)))
(setq ml (cons (assoc g ed) ml))))
(if (not (assoc 67 ml))
(setq ml (cons (cons 67 0) ml)))
(if g-3 (setq ml (cons (assoc -3 ed) ml)))
(entmake (reverse ml))
(if (= (cdr (assoc 66 ed)) 1)
(setq an (entnext en))
(while (/= "SEQEND" (cdr (assoc 0 (entget an))))
(setq ad (entget an)
al nil)
(foreach g fl
(and (assoc g ad)
(setq al (cons (assoc g ad) al))))
(entmake (reverse al))
(setq an (entnext an)))
(entmake (list (cons 0 "SEQEND")
(cons 8 "0")))))
(entdel en)
(setvar "OSMODE" 0)
(setvar "CMDECHO" 0)
(setq fe (entlast))
(command "_.UCS" "_W")
(command "_.UCS" "_E" fe)
(cond ((and (> g71 1)
(> g70 1))
(command "_.ARRAY" fe "" "R" g71 g70 g45 g44))
((> g70 1)
(command "_.ARRAY" fe "" "R" 1 g70 g44))
((> g71 1)
(command "_.ARRAY" fe "" "R" g71 1 g45)))
(foreach g fl (set (read (strcat "g" (itoa g))) nil))
(setq fdi_global_en nil)
(prin1))
You would conversly have edit the group 100 code ( if they can be ) as well 70, 71 ,45 ,44 to make a MINSERT.
This has been a thorn in my side for a long time as I use MINSERTs a lot.
HTH -David
