Author Topic: block group code 71?  (Read 9765 times)
« on: September 29, 2004, 10:56:47 PM »
What if any function is the 71 code in a block and an insert.
The help for Insert says:
    70   Column count (optional; default = 1)
    71   Row count (optional; default = 1)[/list:u]
    Is this only valid if MINSERT blocks? or what?
    Help for block says:
      70   Block-type flags (bit coded values, may be combined):[/list:u]
      No mention of code 71?
      The reason I ask is that I have found some BLOCKS with code 71 . 1
      when I tried to entmake a copy of the block the entmake was rejected with
      message : Invalid field type 71 in (entmake).
« Reply #1 on: September 29, 2004, 11:03:09 PM »
CAB,
Could you post the drawing with this block? As you've found, the 71 code is only present in Minsert'ed inserts(nad should have a corresponding group 45 for the spacing(R2002, please)
Jeff
« Reply #2 on: September 29, 2004, 11:40:16 PM »
Jeff,
Can't post the file, sorry.
The INSERT has codes 70, 71, 44, 45 and are all zero.
And the BLOCK has code 71 . 1
Unknown as to what software produced these blocks.
There are two types of column blocks in plan view.
One square tubing and the other an I beam.
You would expect them to be minserted into the drawing.
SMadsen
« Reply #3 on: September 30, 2004, 07:01:14 AM »
The BLOCK definition has a code 71??
Interesting. Does it get commented if you run an AUDIT?
« Reply #4 on: September 30, 2004, 08:46:26 AM »
Quote from: SMadsen
Command: _audit
Fix any errors detected? [Yes/No] <N>:
 3       Blocks audited
Pass 1 3       objects audited
Pass 2 3       objects audited
Pass 3 100     objects audited
Total errors found 0 fixed 0
Quite a mystery. :)
SMadsen
« Reply #5 on: September 30, 2004, 08:57:59 AM »
Very mysterious.
I've never heard of a code 71 for block defs.
David Bethel
« Reply #6 on: September 30, 2004, 09:12:26 AM »
Up until R13, you could convert a standard INSERT into a MINSERT with (entmod) on groups 70, 71, 44, 45.  With the addition of group 100 codes all of that changed.
Today a MINSERT cannot be edited back into a single INSERT without a little lisp.
;;;CONVERT ( EXPLODE ) MINSERTS INTO SINGLE INSERTS
;;;05-05-2004  ADD XDATA & ATTRIBS ADDED
;;;05-07-2004  CLEANUP
;;;05-08-2004  PRESET DEFAULTS
;;;05-09-2004  FDI GLOBAL ENAME PASSING
(defun c:exmins (/ def ss en ed fe fl ml an ad al)
  (setq def '(("CECOLOR"   . "BYLAYER")
              ("CELTYPE"   . "BYLAYER")
              ("THICKNESS" . 0)
              ("CELTSCALE" . 1)))
  (foreach v def
         (if (getvar (car v))
             (setvar (car v) (cdr v))))
   (not
      (and fdi_global_en
          (= (type fdi_global_en) 'ENAME)
          (entget fdi_global_en)
          (= "INSERT" (cdr (assoc 0 (entget fdi_global_en))))
          (setq en fdi_global_en)))
      (while (or (not ss)
                 (> (sslength ss) 1))
             (princ "\nSelect A MINSERT To Convert:   ")
             (setq ss (ssget (list (cons 0 "INSERT")))))
      (setq en (ssname ss 0))))
  (setq ed (entget en '("*")))
  (setq fl '(0 1 2 6 7 8 10 11 39 40 41 42 43 44 45 50 51 62 66 67 70 71 72 73 74 210 -3))
  (foreach g fl
        (set (read (strcat "g" (itoa g)))
             (cdr (assoc g ed)))
        (and (assoc g ed)
             (not (member g '(-3 44 45 70 71)))
             (setq ml (cons (assoc g ed) ml))))
  (if (not (assoc 67 ml))
      (setq ml (cons (cons 67 0) ml)))
  (if g-3 (setq ml (cons (assoc -3 ed) ml)))
  (entmake (reverse ml))
  (if (= (cdr (assoc 66 ed)) 1)
        (setq an (entnext en))
        (while (/= "SEQEND" (cdr (assoc 0 (entget an))))
               (setq ad (entget an)
                     al nil)
               (foreach g fl
                  (and (assoc g ad)
                       (setq al (cons (assoc g ad) al))))
               (entmake (reverse al))
               (setq an (entnext an)))
       (entmake (list (cons 0 "SEQEND")
                      (cons 8 "0")))))
  (entdel en)
  (setvar "OSMODE" 0)
  (setvar "CMDECHO" 0)
  (setq fe (entlast))
  (command "_.UCS" "_W")
  (command "_.UCS" "_E" fe)
  (cond ((and (> g71 1)
              (> g70 1))
         (command "_.ARRAY" fe "" "R" g71 g70 g45 g44))
        ((> g70 1)
         (command "_.ARRAY" fe "" "R" 1 g70 g44))
        ((> g71 1)
         (command "_.ARRAY" fe "" "R" g71 1 g45)))
  (foreach g fl (set (read (strcat "g" (itoa g))) nil))
  (setq fdi_global_en nil)
  (prin1))
You would conversly have edit the group 100 code ( if they can be ) as well 70, 71 ,45 ,44 to make a MINSERT.
This has been a thorn in my side for a long time as I use MINSERTs a lot.
HTH  -David
R12 Dos - A2K
David Bethel
« Reply #7 on: September 30, 2004, 09:18:16 AM »
On second look, converting INSERTs to MINSERTs does not require group 100 editing.  Acad does it al by itself.
;    BlkXY.Lsp                                Jun 03, 1998
;    Edit Block X Colomn Values
;================== Start Program ======================================
(princ "\nCopyright (C) 1998, Fabricated Designs, Inc.")
(princ "\nLoading BlkXY v1.0 ")
(setq bx_ nil lsp_file "BlkXY")
;================== For Automated Calling From Another Program =========
(defun bx_auto (ar1 ar2 ar3)  ;;;ename space count
   (bx_mod ar1 ar2 ar3))
(defun by_auto (ar1 ar2 ar3)  ;;;ename space count
   (by_mod ar1 ar2 ar3))
;================== Macros =============================================
(defun PDot ()(princ "."))
(defun Beep (/ f)
 (and (wcmatch (getvar "PLATFORM") "*DOS*")
      (setq f (open "con" "w"))
      (write-char '7 f)
      (close f)))
(defun Err (e)
           (beep)
           (princ (strcat "\nError: *** " e " *** "))
           (quit))
;================== Sub Routines =======================================
(PDot);++++++++++++ Set Modes & Error ++++++++++++++++++++++++++++++++++
(defun bx_smd ()
 (SetUndo)
 (setq olderr *error*
      *error* (lambda (e)
                (while (> (getvar "CMDACTIVE") 0)
                       (command))
                (and (/= e "quit / exit abort")
                     (princ (strcat "\nError: *** " e " *** ")))
                (command "_.UNDO" "_END" "_.U")
                (bx_rmd))
       bx_var '(
  ("CMDECHO"   . 0) ("MENUECHO" . 0) ("MENUCTL"   . 0) ("MACROTRACE" . 0)
  ("OSMODE"    . 0) ("SORTENTS" . 119)("MODEMACRO" . ".")
  ("BLIPMODE"  . 0) ("EXPERT"   . 0) ("SNAPMODE"  . 1) ("PLINEWID"   . 0.0)
  ("ORTHOMODE" . 1) ("GRIDMODE" . 0) ("ELEVATION" . 0) ("THICKNESS"  . 0)
  ("FILEDIA"   . 0) ("FILLMODE" . 0) ("SPLFRAME"  . 0) ("UNITMODE"   . 0)
  ("TEXTEVAL"  . 0) ("ATTDIA"   . 0) ("AFLAGS"    . 0) ("ATTREQ"     . 1)
  ("ATTMODE"   . 2) ("UCSICON"  . 1) ("HIGHLIGHT" . 1) ("REGENMODE"  . 1)
  ("COORDS"    . 2) ("DRAGMODE" . 2) ("DIMZIN"    . 1) ("PDMODE"     . 0)
  ("CECOLOR"   . "BYLAYER") ("CELTYPE" . "BYLAYER")))
 (foreach v bx_var
      (setq m_v (cons (getvar (car v)) m_v)
            m_n (cons (car v) m_n))
 (princ (strcat (getvar "PLATFORM") " Release " (ver)
    " -  Edit X Col Y Row Block Spacing ....\n"))
 (princ))
(PDot);++++++++++++ Return Modes & Error +++++++++++++++++++++++++++++++
(defun bx_rmd ()
  (setq *error* olderr)
  (mapcar 'setvar m_n m_v)
  (command "_.UNDO" "_END")
  (prin1))
(PDot);++++++++++++ Set And Start An Undo Group ++++++++++++++++++++++++
(defun SetUndo ()
 (and (zerop (getvar "UNDOCTL"))
      (command "_.UNDO" "_ALL"))
 (and (= (logand (getvar "UNDOCTL") 2) 2)
      (command "_.UNDO" "_CONTROL" "_ALL"))
 (and (= (logand (getvar "UNDOCTL") 8) 8)
      (command "_.UNDO" "_END"))
 (command "_.UNDO" "_GROUP"))
(PDot);++++++++++++ Get Entity Name ++++++++++++++++++++++++++++++++++++
(defun GetOne (/ st os)
 (setq os (getvar "SNAPMODE") s nil)
 (setvar "SNAPMODE" 0)
 (while (not st)
        (setq st (ssget)))
 (while (> (sslength st) 1)
        (setq st nil)
        (princ "\nOnly 1 At A Time Please\n")
        (while (not st)
               (setq st (ssget))))
 (setvar "SNAPMODE" os)
 (setq s (ssname st 0)))
(PDot);++++++++++++ Get Multiple Information Input +++++++++++++++++++++
 (defun by_get ()
  (graphscr)
  (setq row (cdr (assoc 71 bdef))
        ysp (cdr (assoc 45 bdef)))
  (princ (strcat
         "\nInsert Name:  "
         (cdr (assoc 2 bdef))
         (if (cdr (assoc 1 (tblsearch "BLOCK" (cdr (assoc 2 bdef)))))
         " - XRef Definition" " ")))
  (princ (strcat
         "\n     Rows:  " (itoa row)
         "  Spaced At:  " (rtos ysp)))
  (setq ncnt (getint (strcat "\nNew Column Count <" (itoa row) ">:  ")))
  (and (not ncnt) (setq ncnt row))
  (setq nspc (getdist (cdr (assoc 10 bdef)) (strcat "\nNew Column Spacing <" (rtos ysp) ">:   ")))
  (and (not nspc) (setq nspc ysp)))
 (defun bx_get ()
  (graphscr)
  (setq col (cdr (assoc 70 bdef))
        xsp (cdr (assoc 44 bdef)))
  (princ (strcat
         "\nInsert Name:  "
  (princ (strcat
         "\n  Columns:  " (itoa col)
         "  Spaced At:  " (rtos xsp)))
  (setq ncnt (getint (strcat "\nNew Column Count <" (itoa col) ">:  ")))
  (and (not ncnt) (setq ncnt col))
  (setq nspc (getdist (cdr (assoc 10 bdef)) (strcat "\nNew Column Spacing <" (rtos xsp) ">:   ")))
  (and (not nspc) (setq nspc xsp)))
(PDot);++++++++++++ Modify The Block Row Count +++++++++++++++++++++++++
(defun by_mod (e x c)
  (and (= (type e) 'ENAME)
       (= "INSERT" (cdr (assoc 0 (entget e))))
       (numberp x)
       (= (type c) 'INT)
       (setq ed (entget e)
             ed (subst (cons 45 x) (assoc 45 ed) ed)
             ed (subst (cons 71 c) (assoc 71 ed) ed))
       (entmod ed)
       (entupd e)))
(PDot);++++++++++++ Modify The Block Column Count ++++++++++++++++++++++
(defun bx_mod (e x c)
       (numberp x)
       (= (type c) 'INT)
       (setq ed (entget e)
             ed (subst (cons 44 x) (assoc 44 ed) ed)
             ed (subst (cons 70 c) (assoc 70 ed) ed))
       (entmod ed)
       (entupd e)))
(PDot);************ Main Program ***************************************
(defun bx_ (/ m_v m_n olderr bx_var s bdef ncnt nspc col xsp)
  (bx_smd)
  (GetOne)
  (setq bdef (entget s))
  (if (/= "INSERT" (cdr (assoc 0 bdef)))
      (err "Not An Insert Entity"))
  (bx_get)
  (bx_mod s nspc ncnt)
  (bx_rmd))
(defun by_ (/ m_v m_n olderr by_var s bdef ncnt nspc row ysp)
  (bx_smd)
  (GetOne)
  (by_get)
  (by_mod s nspc ncnt)
  (bx_rmd))
(PDot);************ Load Program ***************************************
(defun C:BlkYrow () (by_))
(if by_ (princ "\nBlkYrow Loaded\n"))
(prin1)
(defun C:BlkXCol () (bx_))
(if bx_ (princ "\nBlkXCol Loaded\n"))
(prin1)
;================== End Program ========================================
-David
R12 Dos - A2K
SMadsen
« Reply #8 on: September 30, 2004, 09:37:29 AM »
David, as I understand it, it is the BLOCK definition ("AcDbBlockBegin") that has a code 71. Or maybe a "AcDbBlockTableRecord"?
Am I right, CAB?
« Reply #9 on: September 30, 2004, 09:52:20 AM »
Quote from: SMadsen
Am I right, CAB?
Correctoemundo !!
((-1 . <Entity name: 1bc19e0>)
  (0 . "BLOCK")
  (330 . <Entity name: 1bc19d8>)
  (5 . "2FD4")
  (100 . "AcDbEntity")
  (67 . 0)
  (8 . "0")
  (62 . 0)
  (6 . "Continuous")
  (370 . 0)
  (100 . "AcDbBlockBegin")
  (70 . 0)
  (71 . 1)             <-----------------<<<   ???????
  (10 0.0 0.0 0.0)
  (-2 . <Entity name: 1bc19e8>)
  (2 . "SHS218")
  (1 . "")
David Bethel
« Reply #10 on: September 30, 2004, 10:08:23 AM »
As far as I know, BLOCK table does not contain 71, INSERTs and MINSERTs do.
70 flag in the BLOCK table defines annonymous, attributed, xref, etc.  David
R12 Dos - A2K
« Reply #11 on: September 30, 2004, 10:20:19 AM »
Quote from: David D Bethel
Yes, It is quite a mystery as to how it got there.
I can not get ACAD to accept the code 71 in entmake.
SpeedCAD
« Reply #12 on: September 30, 2004, 10:31:46 AM »
Quote from: CAB
Hi...
The code 71 is:
MINSERT row count and also represent to Attributes and Texts, 0 - 2 - 4
« Reply #13 on: September 30, 2004, 10:54:28 AM »
Quote from: SpeedCAD
The code 71 is:
That if for INSERT's, we are looking at a BLOCK. There is a difference. :)
« Reply #14 on: September 30, 2004, 12:50:45 PM »
Many years ago I used minserts briefly for storing intel. I used invisible minserts because they couldn't be seen, couldn't be exploded and would not be removed by purging or the wblocking "*" technique. Excerpt:
(defun MakeIntelBlockDefinition ( Name )
    ;;  empty block definition
    (foreach x
        (list
            (list
               '(0 . "BLOCK")
                (cons 2 Name)
               '(8 . "0")
               '(10 0.0 0.0 0.0)
               '(70 . 0)
        '(  (0 . "ENDBLK")
            (8 . "0")
      (entmake x)
(defun MakeIntelInsert ( Name )
   (if (null (tblsearch "block" Name))
      (MakeIntelBlockDefinition Name)
   (if (null (tblsearch "appid" Name))
      (regapp Name)
      (entmake
         (list
           '(0 . "INSERT")
           '(100 . "AcDbEntity")
           '(67 . 0)                          ;; modelspace
           '(60 . 1)                          ;; invisible
           '(8 . "0")
           '(100 . "AcDbBlockReference")
            (cons 2 Name)
           '(10 0.0 0.0 0.0)
           '(41 . 1.0)
           '(42 . 1.0)
           '(43 . 1.0)
           '(50 . 0.0)
           '(70 . 1)                          ;; minsert col count
           '(71 . 1)                          ;; minsert row count
           '(44 . 0.0)                        ;; col spacing
           '(45 . 0.0)                        ;; row spacing
           '(210 0.0 0.0 1.0)
            (list -3 (list Name '(1070 . 0))) ;; xdata init
      (entlast)
I abandoned the technique after successfully making persistant data by using hard owned xdictionaries.
(my 2¢).
