Hi!
I am trying to get a piece of code on this forum but i cant find something similar that i need.
I would like a routine that insert a block let's name it "takeout.dwg" on the insertion point of every block in my model that start with the layer "M-N-INC-GIC*" but the block "takeout.dwg" need to be exploded once inserted.
these block are on top of a line, once the takeout inserted i will be able to easily break the line and dimension the "real" pipe length but... one small thing.. once the pipe broke i will get stuck with a useless piece of pipe i don't know the exact measurement at the moment because i am not at job but i will trick my takeout.dwg to leave the pipe with an uncommon length, so its going to be easy to filter these line left alone in the drawing to delete them.
Here i need another small code snippet. something that do..
ssget LINE on LAYER M-N-INC* with an exact length of 24.77mm then delete them IF MEASUREMENT = 1
else
ssget LINE on LAYER M-N-INC* with an exact length of 0.9751 inch then delete them IF MEASUREMENT = 0
Thank you!
