Author Topic: wysiwyg and perspective views...  (Read 14036 times)
CADaver
Re: wysiwyg and perspective views...
« Reply #30 on: March 30, 2009, 11:25:56 PM »
You guys are talking 'perspective'.
do you mean 'perspective' or isometric ??
or some other form of axonometric projection??
James Cannon
« Reply #31 on: March 30, 2009, 11:33:13 PM »
actual perspective, as in the sysvar you can toggle also named perspective.
the problem was that sometimes it RESULTED in an axonometric projection... which was subsequently solved in the above posts.
Was a combo of ensuring WCS was active, and you weren't using the commands on a BLOCK entity, iirc, with a sprinkling of varying versions affecting the outcome.
