Author Topic: wysiwyg and perspective views...  (Read 14035 times)
Co.Mnstr
« on: November 19, 2008, 01:18:13 PM »
Hello all,
Here's what I'm trying to do. In model, space I want to move my orbit around, set it to perspective, and then get a 2d block that looks like the perspective view. I've been able to do this with the parallel view. It took some trial and error, but it worked. Is it possible for me to get the perspective view, and make it into a 2d block. It is easier for me to pass a 2d block to my other ppl.
My process for the parallel is...
use orbit to get the correct angle and look of the objects.
use ucs and set it equal to the view.
name the usc. So it is easier to find again.
rotate the ucs around the x-axis -90.
draw my modeling section line.
correct for any off placement.
then create 2d block section of the entire object.
This gives me a nice 2d block exactly like my view from the beginning, but it is a parallel. Any ideas on how to make this a perspective block?
Thanks all,
Alex
deegeecees
Re: wysiwyg and perspective views...
« Reply #1 on: November 19, 2008, 01:22:10 PM »
It can't be done.
deegeecees
« Reply #2 on: November 19, 2008, 01:23:45 PM »
A work around would be either to have a hiiden line viewport, or take a screenshot of the view you want and pull it in as a raster image.
Matt__W
  • I like my water diluted.
« Reply #3 on: November 19, 2008, 01:32:04 PM »
It can't be done.
LIAR!!!
Command entry: flatshot
Dashboard: 3D Make panel, Flatshot
Creates a 2D or “flattened” representation of all 3D objects in the current view.
   :angel:
Autodesk Expert Elite
deegeecees
« Reply #4 on: November 19, 2008, 02:01:34 PM »
It can't be done in Acad 2004
LIAR!!!
   :angel:
Carp!
Matt__W
« Reply #5 on: November 19, 2008, 02:03:07 PM »
Nice try.   :-D
deegeecees
« Reply #6 on: November 19, 2008, 02:04:35 PM »
Just call me Cliff Claven...   :lol:
I lernt somethin taday, I can go home now. Thankyou Matt.
Maverick®
« Reply #7 on: November 19, 2008, 02:06:31 PM »
Be a Buffalo DG.  Be a Buffalo.
deegeecees
« Reply #8 on: November 19, 2008, 02:22:33 PM »
A herd of buffalo can only move as fast as the slowest buffalo...
Co.Mnstr
« Reply #9 on: November 19, 2008, 02:33:17 PM »
Flashshot... great command.
But, will only work with a parallel view. I did find it cool that if you are set in perspective view when doing the command that it will create a 3d line block of the object. That was cool. I still can not get a perspective 2d block.
I'm still thinking it can't be done.
Matt__W
« Reply #10 on: November 19, 2008, 02:34:12 PM »
I did it.
Post your drawing.
Co.Mnstr
« Reply #11 on: November 19, 2008, 02:50:22 PM »
Here is the file. In one vport you will find the object in parallel, and in the other perspective. Run the flatshot command in both vports and see what happens.
Matt__W
« Reply #12 on: November 19, 2008, 02:59:50 PM »
<Nick Burns> You're welcome! </Nick Burns>
All I did was change the UCS in one of the views to WORLD and *voila*!!
jnieman
« Reply #13 on: November 19, 2008, 03:13:47 PM »
Wow, that is creepy... I actually posted a comment telling Matt he was wrong with Nick Burns tags saying "MOVE OVERRRRRRRRR"
Then I tried it on a simple box in model space, and it worked... and deleted the post before my shame was revealed.
But it did work for me.  UCS was set to world, as well, though, did not try it with a custom UCS
Co.Mnstr
« Reply #14 on: November 19, 2008, 03:21:03 PM »
Here's the same file, and what I did.
Chose the "angle" ucs.
set it to the current plan.
orbit and made the view perspective.
set the view like I want it.
Then set the ucs to world.
run the flatshot command.
The resulting block is in the back ground.
I am using acad2007. Will this make a difference, or is there some system variable I am missing?
BTW thanks to all,
Alex
