Author Topic: Showing Slides in a .NET Form  (Read 9263 times)
It's Alive!
  • Retired
  • AKA Daniel
Re: Showing Slides in a .NET Form
« Reply #15 on: August 29, 2010, 06:44:25 PM »
Nice. I do not need it but thanks.  :lol:
I do not speak English and might not have explained well
You're reading it directly from the file, it's a good job!
« Reply #16 on: August 30, 2010, 11:17:33 AM »
I was thinking the same thing.
The only think left would be to take your code and move it to its own class. then it could be used in a variety of different applications.
« Reply #17 on: August 31, 2010, 03:59:46 AM »
Ok, I have taken the initiative and ported the VB code to C# and built a dll that will create a bitmap from the slide. This bitmap can be assigned to a picture control or any other object that accepts a bitmap image.
The default resolution of the bitmap is 1600x1200 but it can be set by the user as desired, since any zoom or stretch of the bitmap will cause it to look bad.
You can set the bitmap to retain the aspect ratio if desired, otherwise it will fill the bitmap to its extents causing it to be distorted if the aspect ratio isn't the same as the slide.
There are other things that could be done ... and probably will ... in the meantime, the managed code will be a better addition to the toolbox than a COM object.
Source code is included, (VB code complements of jgr)
jgr
« Reply #18 on: September 01, 2010, 12:08:08 PM »
Thank you very much.
jgr
« Reply #19 on: May 27, 2011, 11:05:36 AM »
New (C#) code for playing with slides/slide libraries
- Correctly displays slides created with Motorola 68000-family CPUs (in acad.slb: MEDIT_OT, MEDIT_OC,
MEDIT_MT, MEDIT_MC, MEDIT_CT, MEDIT_CJ,MEDIT_CC, 15W100, 14W100, 13W100, 12W100,
11W100, 10W100, 09W100, 08W100, 07W100, 06W100,05W100, 04W100, 03W100, 02W100)
- Keeps the aspect ratio.
- other code improvements and minor bug fixes
Compile before opening the form designer.
qjchen
  • Best wishes to all
« Reply #20 on: March 21, 2012, 06:36:39 AM »
Thank you, Jgr, it is a rather good program.~
http://qjchen.mjtd.com
My blog http://chenqj.blogspot.com (Chinese, can be translate into English)
neyton
« Reply #21 on: April 01, 2012, 08:44:06 PM »
Uns tempos atraz eu fiz um visualizador de slides em VB.NET, o fonte e o programa estão aqui:
google translate
I did some time behind a slideshow viewer in VB.NET, the source and the program are here:
http://tbn2.blogspot.com/2009/08/slideviewer-source-code.html
Visit my website: http://tbn2.blogspot.com
exmachina
« Reply #22 on: April 02, 2012, 11:37:20 AM »
google translate
Thanks for your contribution, but has many errors. Look here:
http://www.theswamp.org/index.php?topic=34954.0
neyton
« Reply #23 on: April 03, 2012, 09:53:43 AM »
o meu programa é outro, não tem nada a ver com este que você indicou
google translate:
my program is different, has nothing to do with this you indicated
see:
http://tbn2.blogspot.com.br/search?q=slideviewer
