i've been looking at James' importlayer routine as an example, but i've noticed that if the layer already exists in the drawing, it will not alter it (color, linetype, etc.). is it possible to import layers through dbx and have it edit existing layers?
another option, would be to just retrieve all of the selected dwg's layer info in a list ( "layer name" "color" "linetype" "plot/noplot"), from there i could just entmod and create/recreate the layers. i noticed you use vla-get-layers to retrieve the layer name, but i can't figure out how to get the other layer info. is any of this possible?
James' routine that i've been looking at as an example is located here:
http://www.theswamp.org/index.php?topic=24404.new#new
