Author Topic: OpenDCL can do like ...  (Read 6040 times)
xshrimp
  • Mosquito
« on: November 16, 2008, 11:18:06 AM »
command: (setq x '("Line" "" "Circle" "Arc"))
command: (setq y '(0 0 1 2))
(0 0 1 2)
command: (dos_popupmenu x y)
0
command: (dos_popupmenu x)
0
« Last Edit: November 16, 2008, 11:22:19 AM by xshrimp »
abc
Spike Wilbury
Re: OpenDCL can do like ...
« Reply #1 on: November 16, 2008, 11:30:45 AM »
Are you asking if it can be done with OpenDCL ?
(I guess yes - but wait for the helpful users of this application, for a better answer)
HTH.
jbuzbee
« Reply #2 on: November 17, 2008, 09:13:31 AM »
Yes.  But you can actually do that with simple VisualLISP.
;;; Create a POP0 menu ;
;;; Use: (kb:DynamicPop (some list) "kb40") ;
(defun kb:DynamicPop (ulist menugrp / acadobj menugrps menu menus shortcut)
  (setq acadobj  (vlax-get-acad-object)
        menugrps (vla-get-menugroups acadobj)
        menu     (vl-catch-all-apply 'vla-item (list menugrps menugrp))
  (if (not (vl-catch-all-error-p menu))
    (progn (setq menus (vla-get-menus menu))
           (vlax-for
                  i menus
             (if (= (vla-get-shortcutmenu i) :vlax-true)
               (setq shortcut i)
           (if shortcut
             (progn (vlax-for ii shortcut (vla-delete ii))
                    (setq cnt 0)
                    (foreach
                           x ulist
                      (vlax-invoke shortcut 'addmenuitem cnt (car x) (cdr x))
                      (setq cnt (1+ cnt))
  shortcut
The arguments are a list (see the following) and a string of the Menu ID to use.  NOTE: I use a partial menu for the POP0* menuitem.  I havn't tried using the ACAD.POP0* as it might mess things up.  This is how you would build the list:
;;; Return a list of UCSs
;;; use(setq l(kb:ListUCSs))
(defun kb:ListUCSs  (/ ucslist)
  (setq ucslist(list
(cons "World" "ucs World ")
(cons "Bottom" "ucs orthoGraphic Bottom ")
(cons "Front" "ucs orthoGraphic Front ")
(cons "Back" "ucs orthoGraphic Back ")
(cons "Left" "ucs orthoGraphic Left ")
(cons "Right" "ucs orthoGraphic Right ")
(cons "45" "ucs _z 45 ")
(cons "Origin" "ucs _o ")
(cons "Object" "ucs _ob ")
  (vlax-for
         x  (vla-get-UserCoordinateSystems (vla-get-ActiveDocument (vlax-get-acad-object)))
      (setq ucslist (append ucslist (list (cons (vlax-get-property x 'name)(strcat"ucs restore "(vlax-get-property x 'name)" ")
  ucslist)
(defun c:kbUCSPop( / ret)
  (if(kb:DynamicPop (kb:ListUCSs) "kb00")
  (progn (menucmd "P0=kb00.POP0")
(menucmd "P0=*")
Using OpenDCL see this:
http://www.theswamp.org/index.php?topic=25357.0
James Buzbee
Windows 8
xshrimp
  • Mosquito
« Reply #3 on: November 17, 2008, 10:07:25 AM »
 :-) Thank you very much !
abc
KewlToyZ
« Reply #4 on: November 17, 2008, 02:01:28 PM »
Man thats kewl! :kewl:
