Author Topic: Versions of a format of the description 3dSolid  (Read 5957 times)
ElpanovEvgeniy
  • Moscow (Russia)
« on: November 13, 2008, 03:22:32 AM »
Has ripened necessity to gather the information on differences in the description 3dSolid in dxf. First of all, the format header varies each version, in the second, a format of the description, permanently edit. I ask your help - start the program on the computer and copy results of the program on a forum. It will be very useful for my researches, and for going after me.
Especially, results, on computers with vertical solutions of various versions are interesting...
(defun c:test (/ e)
  (setq i 0)
  (princ "\n\n\t*** *** Start log *** ***")
  (princ (strcat "\n\t acadver = " (getvar "acadver") "\n\t "))
  (princ (ver))
  (princ
    (strcat "\n\t SOLIDCHECK = " (itoa (getvar "SOLIDCHECK")))
  (if (getvar "SOLIDHIST")
    (princ
      (strcat "\n\t SOLIDHIST = " (itoa (getvar "SOLIDHIST")))
  (princ "\n\t'(")
  (foreach a (entget
       (setq
e (vlax-vla-object->ename
     (vla-addbox
       (vla-get-ModelSpace
(vla-get-ActiveDocument (vlax-get-acad-object))
       ) ;_  vla-get-ModelSpace
       (vlax-3d-point 10 11 12)
       10
       10
       10
     ) ;_  vla-addbox
   ) ;_  vlax-vla-object->ename
       ) ;_  setq
     ) ;_  entget
    (if (= 1 (car a))
      (princ (strcat "\n\t\t("
     (apply 'strcat
    (mapcar '(lambda (x)
       (if (= x 32)
(chr (- 159 x))
       ) ;_  if
     ) ;_  lambda
    (vl-string->list (cdr a))
    ) ;_  mapcar
     ) ;_  apply
     ) ;_  strcat
      ) ;_  princ
    ) ;_  if
  ) ;_  foreach
  (princ "\n\t)\n\t*** *** End log *** ***")
  (entdel e)
  (textscr)
kpblc
Re: Versions of a format of the description 3dSolid
« Reply #1 on: November 13, 2008, 04:28:15 AM »
AA2008 Eng + SP1:
Command: test
  acadver = 17.1s (LMS Tech)
  Visual LISP 2008 (en)
  SOLIDCHECK = 1
  SOLIDHIST = 1
   (21200 86 2 26          )
   (16 Autodesk AutoCAD 17 ASM 12.0.1.820 NT 0  )
   (1 9.9999999999999995e-007 1e-010 )
   (asmheader $-1 -1 @11 212.0.1.820 #)
   (body $-1 -1 $-1 $2 $-1 $-1 #)
   (lump $-1 -1 $-1 $-1 $3 $1 #)
   (shell $-1 -1 $-1 $-1 $-1 $4 $-1 $2 #)
   (face $-1 -1 $-1 $5 $6 $3 $-1 $7 forward single #)
   (face $-1 -1 $-1 $8 $9 $3 $-1 $10 reversed single #)
   (loop $-1 -1 $-1 $-1 $11 $4 #)
   (plane-surface $-1 -1 $-1 10 11 17 0 0 1 1 0 0 forward_v I I I I #)
   (face $-1 -1 $-1 $12 $13 $3 $-1 $14 reversed single #)
   (loop $-1 -1 $-1 $-1 $15 $5 #)
   (plane-surface $-1 -1 $-1 10 11 7 0 0 1 1 0 0 forward_v I I I I #)
   (coedge $-1 -1 $-1 $16 $17 $18 $19 forward $6 $-1 #)
   (face $-1 -1 $-1 $20 $21 $3 $-1 $22 reversed single #)
   (loop $-1 -1 $-1 $-1 $23 $8 #)
   (plane-surface $-1 -1 $-1 10 6 12 0 1 0 0 0 1 forward_v I I I I #)
   (coedge $-1 -1 $-1 $24 $25 $26 $27 forward $9 $-1 #)
   (coedge $-1 -1 $-1 $28 $11 $29 $30 forward $6 $-1 #)
   (coedge $-1 -1 $-1 $11 $28 $31 $32 forward $6 $-1 #)
   (coedge $-1 -1 $-1 $33 $34 $11 $19 reversed $35 $-1 #)
   (edge $-1 -1 $-1 $36 -5 $37 5 $18 $38 forward @7 unknown #)
   (face $-1 -1 $-1 $39 $40 $3 $-1 $41 reversed single #)
   (loop $-1 -1 $-1 $-1 $42 $12 #)
   (plane-surface $-1 -1 $-1 5 11 12 1 0 0 0 0 -1 forward_v I I I I #)
   (coedge $-1 -1 $-1 $43 $31 $44 $45 forward $13 $-1 #)
   (coedge $-1 -1 $-1 $46 $15 $43 $47 forward $9 $-1 #)
   (coedge $-1 -1 $-1 $15 $46 $48 $49 forward $9 $-1 #)
   (coedge $-1 -1 $-1 $34 $33 $15 $27 reversed $35 $-1 #)
   (edge $-1 -1 $-1 $50 -5 $51 5 $26 $52 forward @7 unknown #)
   (coedge $-1 -1 $-1 $17 $16 $53 $54 forward $6 $-1 #)
   (coedge $-1 -1 $-1 $55 $56 $16 $30 reversed $40 $-1 #)
   (edge $-1 -1 $-1 $37 -5 $57 5 $29 $58 forward @7 unknown #)
   (coedge $-1 -1 $-1 $23 $59 $17 $32 reversed $13 $-1 #)
   (edge $-1 -1 $-1 $60 -5 $36 5 $31 $61 forward @7 unknown #)
   (coedge $-1 -1 $-1 $26 $18 $59 $62 forward $35 $-1 #)
   (coedge $-1 -1 $-1 $18 $26 $55 $63 reversed $35 $-1 #)
   (loop $-1 -1 $-1 $-1 $33 $39 #)
   (vertex $-1 -1 $-1 $19 0 $64 #)
   (vertex $-1 -1 $-1 $19 1 $65 #)
   (straight-curve $-1 -1 $-1 15 11 17 0 1 0 I I #)
   (face $-1 -1 $-1 $-1 $35 $3 $-1 $66 reversed single #)
   (loop $-1 -1 $-1 $-1 $55 $20 #)
   (plane-surface $-1 -1 $-1 10 16 12 0 -1 0 0 0 -1 forward_v I I I I #)
   (coedge $-1 -1 $-1 $67 $53 $56 $68 forward $21 $-1 #)
   (coedge $-1 -1 $-1 $59 $23 $24 $47 reversed $13 $-1 #)
   (coedge $-1 -1 $-1 $53 $67 $23 $45 reversed $21 $-1 #)
   (edge $-1 -1 $-1 $60 -5 $69 5 $44 $70 forward @7 unknown #)
   (coedge $-1 -1 $-1 $25 $24 $67 $71 forward $9 $-1 #)
   (edge $-1 -1 $-1 $51 -5 $69 5 $43 $72 forward @7 unknown #)
   (coedge $-1 -1 $-1 $56 $55 $25 $49 reversed $40 $-1 #)
   (edge $-1 -1 $-1 $73 -5 $50 5 $48 $74 forward @7 unknown #)
   (vertex $-1 -1 $-1 $27 0 $75 #)
   (vertex $-1 -1 $-1 $62 1 $76 #)
   (straight-curve $-1 -1 $-1 15 11 7 0 -1 0 I I #)
   (coedge $-1 -1 $-1 $42 $44 $28 $54 reversed $21 $-1 #)
   (edge $-1 -1 $-1 $57 -5 $60 5 $53 $77 forward @7 unknown #)
   (coedge $-1 -1 $-1 $48 $29 $34 $63 forward $40 $-1 #)
   (coedge $-1 -1 $-1 $29 $48 $42 $68 reversed $40 $-1 #)
   (vertex $-1 -1 $-1 $30 1 $78 #)
   (straight-curve $-1 -1 $-1 10 16 17 -1 0 0 I I #)
   (coedge $-1 -1 $-1 $31 $43 $33 $62 reversed $13 $-1 #)
   (vertex $-1 -1 $-1 $54 1 $79 #)
   (straight-curve $-1 -1 $-1 10 6 17 1 0 0 I I #)
   (edge $-1 -1 $-1 $36 -5 $51 5 $33 $80 forward @7 unknown #)
   (edge $-1 -1 $-1 $37 -5 $50 5 $34 $81 forward @7 unknown #)
   (point $-1 -1 $-1 15 6 17 #)
   (point $-1 -1 $-1 15 16 17 #)
   (plane-surface $-1 -1 $-1 15 11 12 -1 0 0 0 0 1 forward_v I I I I #)
   (coedge $-1 -1 $-1 $44 $42 $46 $71 reversed $21 $-1 #)
   (edge $-1 -1 $-1 $57 -5 $73 5 $56 $82 forward @7 unknown #)
   (vertex $-1 -1 $-1 $71 0 $83 #)
   (straight-curve $-1 -1 $-1 5 6 12 0 0 -1 I I #)
   (edge $-1 -1 $-1 $69 -5 $73 5 $67 $84 forward @7 unknown #)
   (straight-curve $-1 -1 $-1 10 6 7 -1 0 0 I I #)
   (vertex $-1 -1 $-1 $49 0 $85 #)
   (straight-curve $-1 -1 $-1 10 16 7 1 0 0 I I #)
   (point $-1 -1 $-1 15 16 7 #)
   (point $-1 -1 $-1 15 6 7 #)
   (straight-curve $-1 -1 $-1 5 11 17 0 -1 0 I I #)
   (point $-1 -1 $-1 5 16 17 #)
   (point $-1 -1 $-1 5 6 17 #)
   (straight-curve $-1 -1 $-1 15 6 12 0 0 -1 I I #)
   (straight-curve $-1 -1 $-1 15 16 12 0 0 -1 I I #)
   (straight-curve $-1 -1 $-1 5 16 12 0 0 -1 I I #)
   (point $-1 -1 $-1 5 6 7 #)
   (straight-curve $-1 -1 $-1 5 11 7 0 1 0 I I #)
   (point $-1 -1 $-1 5 16 7 #)
Sorry for my English.
SEANT
« Reply #2 on: November 13, 2008, 06:01:38 AM »
AutoCAD Mechanical 2009 SP2 - INSUNITS = Inches
  acadver = 17.2s (LMS Tech)
  Visual LISP 2009 (en)
  SOLIDCHECK = 1
  SOLIDHIST = 1
   (21200 86 2 26          )
   (16 Autodesk AutoCAD 17 ASM 12.0.1.915 NT 0  )
   (25.399999999999999 9.9999999999999995e-007 1e-010 )
   (asmheader $-1 -1 @11 212.0.1.915 #)
Sean Tessier
AutoCAD 2016 Mechanical
« Reply #3 on: November 13, 2008, 08:56:40 AM »
  acadver = 15.0
  Visual LISP 2000 (en)
  SOLIDCHECK = 1
   (400 85 1 0          )
   (7 Unknown 13 ACIS 4.0.2 NT 24 Thu Nov 13 08:48:43 2008 )
   (-1 9.9999999999999995e-007 1e-010 )
   (body $-1 $1 $-1 $-1 #)
   (lump $-1 $-1 $2 $0 #)
   (shell $-1 $-1 $-1 $3 $-1 $1 #)
   (face $-1 $4 $5 $2 $-1 $6 forward single #)
   (face $-1 $7 $8 $2 $-1 $9 reversed single #)
   (loop $-1 $-1 $10 $3 #)
   (plane-surface $-1 10 11 17 0 0 1 1 0 0 forward_v I I I I #)
   (face $-1 $11 $12 $2 $-1 $13 reversed single #)
   (loop $-1 $-1 $14 $4 #)
   (plane-surface $-1 10 11 7 0 0 1 1 0 0 forward_v I I I I #)
   (coedge $-1 $15 $16 $17 $18 forward $5 $-1 #)
   (face $-1 $19 $20 $2 $-1 $21 reversed single #)
   (loop $-1 $-1 $22 $7 #)
   (plane-surface $-1 10 6 12 0 1 0 0 0 1 forward_v I I I I #)
   (coedge $-1 $23 $24 $25 $26 forward $8 $-1 #)
   (coedge $-1 $27 $10 $28 $29 forward $5 $-1 #)
   (coedge $-1 $10 $27 $30 $31 forward $5 $-1 #)
   (coedge $-1 $32 $33 $10 $18 reversed $34 $-1 #)
   (edge $-1 $35 $36 $17 $37 forward #)
   (face $-1 $38 $39 $2 $-1 $40 reversed single #)
   (loop $-1 $-1 $41 $11 #)
   (plane-surface $-1 5 11 12 1 0 0 0 0 -1 forward_v I I I I #)
   (coedge $-1 $42 $30 $43 $44 forward $12 $-1 #)
   (coedge $-1 $45 $14 $42 $46 forward $8 $-1 #)
   (coedge $-1 $14 $45 $47 $48 forward $8 $-1 #)
   (coedge $-1 $33 $32 $14 $26 reversed $34 $-1 #)
   (edge $-1 $49 $50 $25 $51 forward #)
   (coedge $-1 $16 $15 $52 $53 forward $5 $-1 #)
   (coedge $-1 $54 $55 $15 $29 reversed $39 $-1 #)
   (edge $-1 $36 $56 $28 $57 forward #)
   (coedge $-1 $22 $58 $16 $31 reversed $12 $-1 #)
   (edge $-1 $59 $35 $30 $60 forward #)
   (coedge $-1 $25 $17 $58 $61 forward $34 $-1 #)
   (coedge $-1 $17 $25 $54 $62 reversed $34 $-1 #)
   (loop $-1 $-1 $32 $38 #)
   (vertex $-1 $18 $63 #)
   (vertex $-1 $18 $64 #)
   (straight-curve $-1 15 11 17 0 1 0 I I #)
   (face $-1 $-1 $34 $2 $-1 $65 reversed single #)
   (loop $-1 $-1 $54 $19 #)
   (plane-surface $-1 10 16 12 0 -1 0 0 0 -1 forward_v I I I I #)
   (coedge $-1 $66 $52 $55 $67 forward $20 $-1 #)
   (coedge $-1 $58 $22 $23 $46 reversed $12 $-1 #)
   (coedge $-1 $52 $66 $22 $44 reversed $20 $-1 #)
   (edge $-1 $59 $68 $43 $69 forward #)
   (coedge $-1 $24 $23 $66 $70 forward $8 $-1 #)
   (edge $-1 $50 $68 $42 $71 forward #)
   (coedge $-1 $55 $54 $24 $48 reversed $39 $-1 #)
   (edge $-1 $72 $49 $47 $73 forward #)
   (vertex $-1 $26 $74 #)
   (vertex $-1 $61 $75 #)
   (straight-curve $-1 15 11 7 0 -1 0 I I #)
   (coedge $-1 $41 $43 $27 $53 reversed $20 $-1 #)
   (edge $-1 $56 $59 $52 $76 forward #)
   (coedge $-1 $47 $28 $33 $62 forward $39 $-1 #)
   (coedge $-1 $28 $47 $41 $67 reversed $39 $-1 #)
   (vertex $-1 $29 $77 #)
   (straight-curve $-1 10 16 17 -1 0 0 I I #)
   (coedge $-1 $30 $42 $32 $61 reversed $12 $-1 #)
   (vertex $-1 $53 $78 #)
   (straight-curve $-1 10 6 17 1 0 0 I I #)
   (edge $-1 $35 $50 $32 $79 forward #)
   (edge $-1 $36 $49 $33 $80 forward #)
   (point $-1 15 6 17 #)
   (point $-1 15 16 17 #)
   (plane-surface $-1 15 11 12 -1 0 0 0 0 1 forward_v I I I I #)
   (coedge $-1 $43 $41 $45 $70 reversed $20 $-1 #)
   (edge $-1 $56 $72 $55 $81 forward #)
   (vertex $-1 $70 $82 #)
   (straight-curve $-1 5 6 12 0 0 -1 I I #)
   (edge $-1 $68 $72 $66 $83 forward #)
   (straight-curve $-1 10 6 7 -1 0 0 I I #)
   (vertex $-1 $48 $84 #)
   (straight-curve $-1 10 16 7 1 0 0 I I #)
   (point $-1 15 16 7 #)
   (point $-1 15 6 7 #)
   (straight-curve $-1 5 11 17 0 -1 0 I I #)
   (point $-1 5 16 17 #)
   (point $-1 5 6 17 #)
   (straight-curve $-1 15 6 12 0 0 -1 I I #)
   (straight-curve $-1 15 16 12 0 0 -1 I I #)
   (straight-curve $-1 5 16 12 0 0 -1 I I #)
   (point $-1 5 6 7 #)
   (straight-curve $-1 5 11 7 0 1 0 I I #)
   (point $-1 5 16 7 #)
« Reply #4 on: November 13, 2008, 09:00:09 AM »
  acadver = 16.0
  Visual LISP 2004 (en)
  SOLIDCHECK = 1
   (20800 86 2 0          )
   (16 Autodesk AutoCAD 17 ASM 6.0.5.7004 NT 24 Thu Nov 13 08:52:49 2008 )
   (asmheader $-1 -1 @12 208.0.5.7004 #)
   (vertex $-1 -1 $-1 $19 $64 #)
   (vertex $-1 -1 $-1 $19 $65 #)
   (vertex $-1 -1 $-1 $27 $75 #)
   (vertex $-1 -1 $-1 $62 $76 #)
   (vertex $-1 -1 $-1 $30 $78 #)
   (vertex $-1 -1 $-1 $54 $79 #)
   (vertex $-1 -1 $-1 $71 $83 #)
   (vertex $-1 -1 $-1 $49 $85 #)
« Reply #5 on: November 13, 2008, 09:02:21 AM »
  acadver = 16.2s (LMS Tech)
  Visual LISP 2006 (en)
  SOLIDCHECK = 1
   (20800 86 2 0          )
   (16 Autodesk AutoCAD 17 ASM 6.0.5.7004 NT 24 Thu Nov 13 08:54:55 2008 )
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #6 on: November 13, 2008, 09:06:05 AM »
Many thanks Friends! :)
Chris
« Reply #7 on: November 13, 2008, 10:55:51 AM »
Vanilla AutoCAD 2009 SP2, Bonus Pack 1
  SOLIDCHECK = 1
  SOLIDHIST = 1
   (21200 86 2 26          )
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
« Reply #8 on: November 13, 2008, 11:17:36 AM »
AutoCAD 2006 Electrical SP2a
Command: test
  SOLIDCHECK = 1
   (20800 86 2 0          )
   (16 Autodesk AutoCAD 17 ASM 6.0.5.7004 NT 24 Thu Nov 13 08:15:06 2008 )
« Reply #9 on: November 13, 2008, 11:19:48 AM »
AutoCAD 2008 Electrical No SPs
Command: test
  SOLIDCHECK = 1
  SOLIDHIST = 1
   (21200 86 2 26          )
VovKa
  • Ukraine
« Reply #10 on: November 13, 2008, 11:23:42 AM »
Map 2005
  acadver = 16.1s (LMS Tech)
  Visual LISP 2005 (en)
  SOLIDCHECK = 1
   (20800 86 2 0          )
   (16 Autodesk AutoCAD 17 ASM 6.0.4.7009 NT 24 Thu Nov 13 18:21:11 2008 )
   (asmheader $-1 -1 @12 208.0.4.7009 #)
gile
  • Marseille, France
« Reply #11 on: November 13, 2008, 04:59:26 PM »
  acadver = 17.0s (LMS Tech)
  Visual LISP 2007 (fr)
  SOLIDCHECK = 1
  SOLIDHIST = 1
   (21200 86 2 26          )
   (16 Autodesk AutoCAD 18 ASM 12.0.0.5828 NT 0  )
   (asmheader $-1 -1 @12 212.0.0.5828 #)
SEANT
« Reply #12 on: November 16, 2008, 05:31:45 AM »
I’ve never spent much time examining 3DSolids from this approach.  Apparently there is a lot to see and manipulate if a person has the expertise.
Is it safe to say that the information exposed with your routine is the same as would be derived from an Acisout command?
The reason I ask is that it is a quite common requirement to transfer Solids from other applications (in my case Rhino 3D) to AutoCAD.  The only path is via the .SAT format.  Sadly, this transfer is less than perfect (not necessarily with flat faced solids but certainly with those including non-planar faces).
I don’t imagine you have much interest in the predicaments of Rhino 3D users but thought I’d post the description below as an interesting comparison.  It is an Acis export of a similar 3d Box.
400 0 1 0
7 Unknown 13 ACIS 5.0.1 NT 24 Sun Nov 16 10:12:55 2008
-0 body $-1 $2 $-1 $1 #
-1 transform $-1 1 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0 #
-2 lump $-1 $-1 $3 $0 #
-3 shell $-1 $-1 $-1 $4 $-1 $2 #
-4 face $-1 $15 $6 $3 $-1 $5 forward single #
-5 spline-surface $-1 forward { exactsur nubs 1 1 open open none none 2 2
        0 1 10 1
        0 1 10 1
        5 6 7
        15 6 7
        5 6 17
        15 6 17
        0
        0
        0
        0
        0
        0
        0
        F 0 F 10 F 0 F 10 } F 0 F 10 F 0 F 10 #
-6 loop $-1 $-1 $7 $4 #
-7 coedge $-1 $9 $13 $57 $70 forward $6 $8 #
-8 pcurve $-1 0 forward { exppc nubs 1 open 2
        0 1 10 1
        0 0
        10 0
        0
        spline 0 { ref 0 } F 0 F 10 F 0 F 10
        } 0 0 #
-9 coedge $-1 $11 $7 $24 $88 forward $6 $10 #
-10 pcurve $-1 0 forward { exppc nubs 1 open 2
        0 1 10 1
        10 0
        10 10
        0
        } 0 0 #
-11 coedge $-1 $13 $9 $62 $78 reversed $6 $12 #
-12 pcurve $-1 0 forward { exppc nubs 1 open 2
        -10 1 0 1
        10 10
        0 10
        0
        } 0 0 #
-13 coedge $-1 $7 $11 $42 $86 reversed $6 $14 #
-14 pcurve $-1 0 forward { exppc nubs 1 open 2
        -10 1 0 1
        0 10
        0 0
        0
        } 0 0 #
-15 face $-1 $26 $17 $3 $-1 $16 forward single #
-16 spline-surface $-1 forward { exactsur nubs 1 1 open open none none 2 2
        0 1 10 1
        0 1 10 1
        15 6 7
        15 16 7
        15 6 17
        15 16 17
        0
        0
        0
        0
        0
        0
        0
-17 loop $-1 $-1 $18 $15 #
-18 coedge $-1 $20 $24 $55 $72 forward $17 $19 #
-19 pcurve $-1 0 forward { exppc nubs 1 open 2
        0 1 10 1
        0 0
        10 0
        0
        spline 0 { ref 5 } F 0 F 10 F 0 F 10
        } 0 0 #
-20 coedge $-1 $22 $18 $35 $90 forward $17 $21 #
-21 pcurve $-1 0 forward { exppc nubs 1 open 2
        0 1 10 1
        10 0
        10 10
        0
        } 0 0 #
-22 coedge $-1 $24 $20 $64 $80 reversed $17 $23 #
-23 pcurve $-1 0 forward { exppc nubs 1 open 2
        -10 1 0 1
        10 10
        0 10
        0
        } 0 0 #
-24 coedge $-1 $18 $22 $9 $88 reversed $17 $25 #
-25 pcurve $-1 0 forward { exppc nubs 1 open 2
        -10 1 0 1
        0 10
        0 0
        0
        } 0 0 #
-26 face $-1 $37 $28 $3 $-1 $27 forward single #
-27 spline-surface $-1 forward { exactsur nubs 1 1 open open none none 2 2
        0 1 10 1
        0 1 10 1
        15 16 7
        5 16 7
        15 16 17
        5 16 17
        0
        0
        0
        0
        0
        0
        0
-28 loop $-1 $-1 $29 $26 #
-29 coedge $-1 $31 $35 $53 $74 forward $28 $30 #
-30 pcurve $-1 0 forward { exppc nubs 1 open 2
        0 1 10 1
        0 0
        10 0
        0
        spline 0 { ref 10 } F 0 F 10 F 0 F 10
        } 0 0 #
-31 coedge $-1 $33 $29 $46 $92 forward $28 $32 #
-32 pcurve $-1 0 forward { exppc nubs 1 open 2
        0 1 10 1
        10 0
        10 10
        0
        } 0 0 #
-33 coedge $-1 $35 $31 $66 $82 reversed $28 $34 #
-34 pcurve $-1 0 forward { exppc nubs 1 open 2
        -10 1 0 1
        10 10
        0 10
        0
        } 0 0 #
-35 coedge $-1 $29 $33 $20 $90 reversed $28 $36 #
-36 pcurve $-1 0 forward { exppc nubs 1 open 2
        -10 1 0 1
        0 10
        0 0
        0
        } 0 0 #
-37 face $-1 $48 $39 $3 $-1 $38 forward single #
-38 spline-surface $-1 forward { exactsur nubs 1 1 open open none none 2 2
        0 1 10 1
        0 1 10 1
        5 16 7
        5 6 7
        5 16 17
        5 6 17
        0
        0
        0
        0
        0
        0
        0
-39 loop $-1 $-1 $40 $37 #
-40 coedge $-1 $42 $46 $51 $76 forward $39 $41 #
-41 pcurve $-1 0 forward { exppc nubs 1 open 2
        0 1 10 1
        0 0
        10 0
        0
        spline 0 { ref 15 } F 0 F 10 F 0 F 10
        } 0 0 #
-42 coedge $-1 $44 $40 $13 $86 forward $39 $43 #
-43 pcurve $-1 0 forward { exppc nubs 1 open 2
        0 1 10 1
        10 0
        10 10
        0
        } 0 0 #
-44 coedge $-1 $46 $42 $68 $84 reversed $39 $45 #
-45 pcurve $-1 0 forward { exppc nubs 1 open 2
        -10 1 0 1
        10 10
        0 10
        0
        } 0 0 #
-46 coedge $-1 $40 $44 $31 $92 reversed $39 $47 #
-47 pcurve $-1 0 forward { exppc nubs 1 open 2
        -10 1 0 1
        0 10
        0 0
        0
        } 0 0 #
-48 face $-1 $59 $50 $3 $-1 $49 forward single #
-49 spline-surface $-1 forward { exactsur nubs 1 1 open open none none 2 2
        0 1 10 1
        0 1 10 1
        5 6 7
        5 16 7
        15 6 7
        15 16 7
        0
        0
        0
        0
        0
        0
        0
-50 loop $-1 $-1 $51 $48 #
-51 coedge $-1 $53 $57 $40 $76 reversed $50 $52 #
-52 pcurve $-1 0 forward { exppc nubs 1 open 2
        -10 1 0 1
        0 0
        10 0
        0
        spline 0 { ref 20 } F 0 F 10 F 0 F 10
        } 0 0 #
-53 coedge $-1 $55 $51 $29 $74 reversed $50 $54 #
-54 pcurve $-1 0 forward { exppc nubs 1 open 2
        -10 1 0 1
        10 0
        10 10
        0
        } 0 0 #
-55 coedge $-1 $57 $53 $18 $72 reversed $50 $56 #
-56 pcurve $-1 0 forward { exppc nubs 1 open 2
        -10 1 0 1
        10 10
        0 10
        0
        } 0 0 #
-57 coedge $-1 $51 $55 $7 $70 reversed $50 $58 #
-58 pcurve $-1 0 forward { exppc nubs 1 open 2
        -10 1 0 1
        0 10
        0 0
        0
        } 0 0 #
-59 face $-1 $-1 $61 $3 $-1 $60 forward single #
-60 spline-surface $-1 forward { exactsur nubs 1 1 open open none none 2 2
        0 1 10 1
        0 1 10 1
        5 6 17
        15 6 17
        5 16 17
        15 16 17
        0
        0
        0
        0
        0
        0
        0
-61 loop $-1 $-1 $62 $59 #
-62 coedge $-1 $64 $68 $11 $78 forward $61 $63 #
-63 pcurve $-1 0 forward { exppc nubs 1 open 2
        0 1 10 1
        0 0
        10 0
        0
        spline 0 { ref 25 } F 0 F 10 F 0 F 10
        } 0 0 #
-64 coedge $-1 $66 $62 $22 $80 forward $61 $65 #
-65 pcurve $-1 0 forward { exppc nubs 1 open 2
        0 1 10 1
        10 0
        10 10
        0
        } 0 0 #
-66 coedge $-1 $68 $64 $33 $82 forward $61 $67 #
-67 pcurve $-1 0 forward { exppc nubs 1 open 2
        0 1 10 1
        10 10
        0 10
        0
        } 0 0 #
-68 coedge $-1 $62 $66 $44 $84 forward $61 $69 #
-69 pcurve $-1 0 forward { exppc nubs 1 open 2
        0 1 10 1
        0 10
        0 0
        0
        } 0 0 #
-70 edge $-1 $94 $96 $7 $71 forward #
-71 intcurve-curve $-1 forward { exactcur nubs 1 open 2
        0 1 10 1
        5 6 7
        15 6 7
        0
        null_surface
        null_surface
        nullbs
        nullbs
        I I
        0
        0
        0
        F 0 F 10 } F 0 F 10 #
-72 edge $-1 $96 $98 $18 $73 forward #
-73 intcurve-curve $-1 forward { exactcur nubs 1 open 2
        0 1 10 1
        15 6 7
        15 16 7
        0
        null_surface
        null_surface
        nullbs
        nullbs
        I I
        0
        0
        0
-74 edge $-1 $98 $100 $29 $75 forward #
-75 intcurve-curve $-1 forward { exactcur nubs 1 open 2
        0 1 10 1
        15 16 7
        5 16 7
        0
        null_surface
        null_surface
        nullbs
        nullbs
        I I
        0
        0
        0
-76 edge $-1 $100 $94 $40 $77 forward #
-77 intcurve-curve $-1 forward { exactcur nubs 1 open 2
        0 1 10 1
        5 16 7
        5 6 7
        0
        null_surface
        null_surface
        nullbs
        nullbs
        I I
        0
        0
        0
-78 edge $-1 $102 $104 $11 $79 forward #
-79 intcurve-curve $-1 forward { exactcur nubs 1 open 2
        0 1 10 1
        5 6 17
        15 6 17
        0
        null_surface
        null_surface
        nullbs
        nullbs
        I I
        0
        0
        0
-80 edge $-1 $104 $106 $22 $81 forward #
-81 intcurve-curve $-1 forward { exactcur nubs 1 open 2
        0 1 10 1
        15 6 17
        15 16 17
        0
        null_surface
        null_surface
        nullbs
        nullbs
        I I
        0
        0
        0
-82 edge $-1 $106 $108 $33 $83 forward #
-83 intcurve-curve $-1 forward { exactcur nubs 1 open 2
        0 1 10 1
        15 16 17
        5 16 17
        0
        null_surface
        null_surface
        nullbs
        nullbs
        I I
        0
        0
        0
-84 edge $-1 $108 $102 $44 $85 forward #
-85 intcurve-curve $-1 forward { exactcur nubs 1 open 2
        0 1 10 1
        5 16 17
        5 6 17
        0
        null_surface
        null_surface
        nullbs
        nullbs
        I I
        0
        0
        0
-86 edge $-1 $94 $102 $13 $87 forward #
-87 intcurve-curve $-1 forward { exactcur nubs 1 open 2
        0 1 10 1
        5 6 7
        5 6 17
        0
        null_surface
        null_surface
        nullbs
        nullbs
        I I
        0
        0
        0
-88 edge $-1 $96 $104 $9 $89 forward #
-89 intcurve-curve $-1 forward { exactcur nubs 1 open 2
        0 1 10 1
        15 6 7
        15 6 17
        0
        null_surface
        null_surface
        nullbs
        nullbs
        I I
        0
        0
        0
-90 edge $-1 $98 $106 $20 $91 forward #
-91 intcurve-curve $-1 forward { exactcur nubs 1 open 2
        0 1 10 1
        15 16 7
        15 16 17
        0
        null_surface
        null_surface
        nullbs
        nullbs
        I I
        0
        0
        0
-92 edge $-1 $100 $108 $31 $93 forward #
-93 intcurve-curve $-1 forward { exactcur nubs 1 open 2
        0 1 10 1
        5 16 7
        5 16 17
        0
        null_surface
        null_surface
        nullbs
        nullbs
        I I
        0
        0
        0
-94 vertex $-1 $70 $95 #
-95 point $-1 5 6 7 #
-96 vertex $-1 $70 $97 #
-97 point $-1 15 6 7 #
-98 vertex $-1 $72 $99 #
-99 point $-1 15 16 7 #
-100 vertex $-1 $74 $101 #
-101 point $-1 5 16 7 #
-102 vertex $-1 $78 $103 #
-103 point $-1 5 6 17 #
-104 vertex $-1 $78 $105 #
-105 point $-1 15 6 17 #
-106 vertex $-1 $80 $107 #
-107 point $-1 15 16 17 #
-108 vertex $-1 $82 $109 #
-109 point $-1 5 16 17 #
End-of-ACIS-data
Sean Tessier
Amsterdammed
« Reply #13 on: November 16, 2008, 02:37:44 PM »
  Visual LISP 2007 (en)
  SOLIDCHECK = 1
  SOLIDHIST = 1
   (21200 86 2 26          )
   (16 Autodesk AutoCAD 18 ASM 12.0.0.5822 NT 0  )
   (asmheader $-1 -1 @12 212.0.0.5822 #)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #14 on: January 10, 2022, 05:58:48 AM »
For my programs, I used this manual. This is not exactly the same format as in AutoCAD, but the description of the format helps a lot.
