Author Topic: Cycle between viewports (Ctrl + R) doesn't work  (Read 1665 times)
Matt__W
  • I like my water diluted.
« on: November 12, 2008, 09:30:06 AM »
I'm running MEP 2008 and CTRL+R to cycle through viewports doesn't work.  It's supposed to, but it doesn't.  Does anyone know of any sysvars that may interfere with this working correctly or another way of cycling through viewports?
Autodesk Expert Elite
Matt__W
Re: Cycle between viewports (Ctrl + R) doesn't work
« Reply #1 on: November 12, 2008, 09:32:48 AM »
Update:
Ctrl+R works in Civil 3D 2008.
jonesy
  • SuperMod
« Reply #2 on: November 12, 2008, 09:36:52 AM »
I was having problems with mine last week. I checked it was assigned in the CUI. When I closed out of the CUI it seemed to work just fine. I didnt change anything tho...
Rob...
« Reply #3 on: November 12, 2008, 09:47:33 AM »
Doesn't work for me in MEP 2008 either.
CAD Tech
Matt__W
« Reply #4 on: November 12, 2008, 09:59:26 AM »
I just added it to the CUI  (CTRL+R = ^V ) and now it works.
Hedgehog
« Reply #5 on: November 12, 2008, 10:01:51 AM »
I don't know if there's a specific conflict with MEP but my MEP 2009 is fine... check in your CUI under Keyboard Shortcuts - Shortcut Keys - CTRL+R which should have ^V in the macro field... & of course CTRL+R in the key(s) field... it's just possible it's become corrupted.
Hedgehog
« Reply #6 on: November 12, 2008, 10:13:57 AM »
... aha... just checked my MEP 2008 & sure enough it isn't in the CUI... I had to duplicate the CTRL+H entry & edit it as above.
KewlToyZ
« Reply #7 on: November 12, 2008, 01:29:57 PM »
I'm contemplating a phase out of 2008 in favor of 2009.
It loads faster and actually closes when I tell it to close.
Not to mention I'm still supporting Standards and folders for 2007 Vanilla through 2009 MEP.
Unfortunately the latest 2009 MEP Service pack does that lousy error code: 3010 on every workstation.
And NVIDIA still hasn't fixed their stupid CAD drivers to include the MEP version of AutoCAD.
I've been complaining to them for months about that.
