Author Topic: Why cann't it delete a layer?  (Read 2860 times)
itcad
« on: November 12, 2008, 04:08:23 AM »
the code :
public  void DeleteLayer(string layerName)
             ObjectId layerId = ObjectId.Null;
             Database db = HostApplicationServices.WorkingDatabase;
             Transaction trans = db.TransactionManager.StartTransaction();
             LayerTable lt = (LayerTable)trans.GetObject(db.LayerTableId, OpenMode.ForWrite, true);
             if (lt.Has(layerName))
                 layerId = lt[layerName];
               if (lt[layerName].IsErased==false)
                     LayerTableRecord ltr = (LayerTableRecord)trans.GetObject(layerId, OpenMode.ForWrite,true);
                     ltr.Erase();
             trans.Commit();
             trans.Dispose();
Glenn R
Re: Why cann't it delete a layer?
« Reply #1 on: November 12, 2008, 05:06:35 AM »
Without seeing any error you might be getting, I would suggest that it's either:
A: The layer you're trying to delete is the current layer, or,
B: The layer you're trying to delete has geometry or something else referencing it in the drawing.
Or, you've run into the dreaded 'default indexer' bug on the SymbolTables.
