If you just want to copy from one drawing to the current, than that shouldn't be too hard, as long as the xrefs are named the same. If not, then some mapping will come into play. This could be done with VBA ( stated because I know you can code in it ). If that is what you are after it wouldn't be too hard to come up with something. Do you want to code it in VBA ( I can't really help, but give some ideas that I would use with Lisp and ActiveX )? Or do you want to do it in Lisp?
