Author Topic: Math Formula Needed  (Read 5400 times)
Re: Math Formula Needed
« Reply #15 on: November 04, 2008, 05:28:26 PM »
Stress will be the tension in lbs divided by the cross sectional area of the rod.
And Port is right, my solution was for the drawing shown. Port's solution can be used for other triangles, just substitute your H & W values.
My solution stayed away from trig (sort of) and is:
 T=W*L/H
Where T=tension in lbs, W= load, L=length of hypotenuse, and H=height.
Nerd  :-D
« Reply #16 on: November 04, 2008, 05:40:18 PM »
I understand now.
I love this stuff :roll:
« Reply #17 on: November 04, 2008, 05:49:53 PM »
I was trying to get the formula in a LISP form but don't know what to do with the -1 power.
(/ load (sin(tan (/ H W))))Hight & Width
jnieman
« Reply #18 on: November 04, 2008, 05:56:36 PM »
I'm sticking with my reply :P
Strucmad
« Reply #19 on: November 04, 2008, 05:56:49 PM »
tan-1 is the inverse tan or (arctan)
found this it might help. (note radians)
http://www.afralisp.net/Tips/code20.htm
Strucmad
« Reply #20 on: November 04, 2008, 06:00:22 PM »
sorry mate a man of your experience would know the (radians) thing....
I didn't need to point that one out.. :oops:
Spike Wilbury
« Reply #21 on: November 04, 2008, 06:06:52 PM »
just in case - load is a lisp function - ..... :)
Atook
  • AKA Tim
« Reply #22 on: November 04, 2008, 06:24:47 PM »
CAB, my equation is the same as Port's, just without any trig functions (you could say they've been evaluated already).
SohCahToa right? :)
Strucmad
« Reply #23 on: November 04, 2008, 06:39:13 PM »
Atook, your right there.
CAB just divide the hypotenuse by the height and multiply by load
(* load (/  (sqrt (+ (* h h) (*w w))) h))
I'm not good at lisp, someone might need to check the syntax  :oops:
« Reply #24 on: November 04, 2008, 06:55:14 PM »
Thanks Luis I just threw the load in there at the posting  for readability.
PS_Port, Arctan I understand but did not recognize it as tan-1
This works just fine.
_$ (setq l 500 h 35.5 w 54.5)(* l (/  (sqrt (+ (* h h) (* w w))) h))
916.089
« Last Edit: November 04, 2008, 06:59:32 PM by CAB »
Strucmad
« Reply #25 on: November 04, 2008, 06:57:44 PM »
Cool bananas
I get thrown with arctan  :-D
« Reply #26 on: November 04, 2008, 07:04:51 PM »
This works as well.  8-)
(/ 500(sin(atan (/ 35.5 54.5))))
916.089
So here is the final test.
(setq W 500 H 35.5 L 54.5)
(setq T (/ W (sin (atan (/ L H)))))
916.089
(setq T (* W (/  (sqrt (+ (* H H) (* L L))) H)))
916.089
« Last Edit: November 04, 2008, 07:11:27 PM by CAB »
Bob Garner
« Reply #27 on: November 04, 2008, 08:26:48 PM »
My company wouldn't let us use the net today (!?).  I'm finally home from a really long day and not presently capable of doing any math at all so I'm worthless.  But looks like everyone's covered it well.  All day I had that song on my mind, "Whiskey for my horses, champaigne for my men".  After reading all your posts, I'm singing, "Whiskey for my horses, Pay raises for the Swampers".
Kips are in units of 1000 pounds or one kip = one thousand pounds.  Anybody know who the hell Kip is?
Happy evening all.  May your votes work out for you.
Bob
« Reply #28 on: November 04, 2008, 10:10:04 PM »
Bob,
Hope tomorrow is a better one. 8-)
Notsober
« Reply #29 on: November 04, 2008, 10:32:53 PM »
yes. Kip is that burned-out engineer who needs help with his "engineering" from a guy named Robert that just so happens to be gifted with pointing out all of his mistakes.
Dr. George: "Good catch, Robert, wow! **makes sounds of a crowd screaming**
I need to make a youtube video of the engineer here... y'all would laugh your (_Y_)'s off!
