Author Topic: Xref overlay without detach  (Read 9208 times)
cadpro
« on: November 04, 2008, 03:49:21 AM »
Can xref be overlayed without detaching it?
Re: Xref overlay without detach
« Reply #1 on: November 04, 2008, 04:10:52 AM »
If you detach it, the xref cant be overlayed or attached .. cause it is detached and not linked(referenced) into the drawing.
« Reply #2 on: November 04, 2008, 04:23:44 AM »
.. and i see that you've posted the same question on autodesk.autocad.customization.dotnet.
will be interesting to see if you get a different answer.
ps;
I haven't checked, but it seems that almost every question you've asked for the last couple of years has been about xrefs ... you should be an expert at them shortly :D
Glenn R
« Reply #3 on: November 04, 2008, 06:03:14 AM »
 :lmao:
cadpro
« Reply #4 on: November 04, 2008, 07:47:12 AM »
ps;
I wish I could be!   :wink:
« Last Edit: November 04, 2008, 07:53:35 AM by cadpro »
cadpro
« Reply #5 on: November 04, 2008, 07:50:34 AM »
All sample codes that I saw throughout the threads do a detach of the same xref before changing it to overlay. But, this doesn't work if the block is xrefed in multiple layouts.
Is there a way to access the xrefmanager to change the xref to overlay?
jmaeding
« Reply #6 on: November 04, 2008, 11:05:55 AM »
I'd like to know too, it seems like it would be such an easy thing to put in the API.
I would use that in about three different tools I can think of.
James Maeding
jmaeding
« Reply #7 on: November 04, 2008, 11:10:42 AM »
wait, this is a duplicate thread, let's keep to the other one with all the code.
James Maeding
« Reply #8 on: November 04, 2008, 11:16:32 AM »
You can try the lisp code here [ http://www.theswamp.org/index.php?topic=25232.0 ].  If it works for you, then you should be able to change it to .Net for your purpose, but it does detach and reattach the xref as the type you want.
Bryco
« Reply #9 on: November 04, 2008, 12:54:03 PM »
At a guess, when you change an xref (w/ multiple inserts) from insert to overlay they all change at the same time. So remove all xrefs with that name and reinsert them.  Oh I guess you already tried that and it didn't work, silly me.
cadpro
« Reply #10 on: November 05, 2008, 12:08:30 AM »
That is the issue!  :ugly:
cadpro
« Reply #11 on: November 05, 2008, 12:20:05 AM »
That didn't work.
« Reply #12 on: November 05, 2008, 06:47:48 PM »
That didn't work.
Are you working with nested xrefs?  If so, then it wasn't tested for that since I don't use them.  If not, then maybe you can post the drawing file and xrefs, so that I can test.
cadpro
« Reply #13 on: November 11, 2008, 03:19:07 AM »
No nested xrefs. Only title blocks.
jjs
« Reply #14 on: November 14, 2008, 01:55:51 PM »
Why can't you record all the insertion information, then detach and reattach?
You could save a layerstate before and reapply it afterward.
Insertion points and scale factors should not be hard.
