I don't lisp much, only enough to execute vb stuff. So my question is this:
If I have a lisp routine that is in my appload\contents, so it is loaded on startup, is this lisp routine executed every time a new drawing is opened? so s::startup is triggered on every startup, correct?
If this is true, and in my startup routine I have a section where I vl-file-copy a bunch of files from the network to the local drive, does this mean that these files are copied down everytime a files is opened?
If so, is there a way to prevent this, maybe only trigger on startup of application?
Thanks,
Viktor.
