Author Topic: Can LispFunction return an atom ?  (Read 5234 times)
gile
  • Marseille, France
« on: October 25, 2008, 07:17:47 AM »
I try to learn C#, creating some LISP extensions.
I read some post (here and there) about ResultBuffer to get the function arguments and to return the function result.
But this way the returned value is a list, i.e. (don't laught, I'm a complete beginner)
using System;
namespace DivLisp
    public class DivLisp
        [LispFunction("div")]
        public ResultBuffer div(ResultBuffer args)
            Array inputArgs = args.AsArray();
            double arg1 = Convert.ToDouble(((TypedValue)(inputArgs.GetValue(0))).Value);
            double arg2 = Convert.ToDouble(((TypedValue)(inputArgs.GetValue(1))).Value);
            ResultBuffer result = new ResultBuffer(new TypedValue((int)LispDataType.Double, (arg1 / arg2)));
            return result;
Commande: (div 10 3)
(3.33333)
Is there a way so that a LISP function which requieres arguments returns an atom (i.e. (div 10 3) returns 3.33333)
It's Alive!
  • Retired
  • AKA Daniel
Re: Can LispFunction return an atom ?
« Reply #1 on: October 25, 2008, 08:17:55 AM »
Hi gile,
The LispFunction can return any of these types.
From the docs..
int
double
TypedValue
ResultBuffer
string
Point2d
Point3d
bool
void
ObjectId
SelectionSet
Since in C#, any type can be cast as an Object, you can just return an Object I.e
   [LispFunction("Lisp1")]
    public static Object Lisp1(ResultBuffer resBuf)
      if (resBuf == null)
        return false;
      else
        return true;
gile
  • Marseille, France
« Reply #2 on: October 25, 2008, 08:37:24 AM »
Thank you very much Daniel, it was so simple !!!
This made me understand a little more how works C# and how many I have to learn...
It's Alive!
  • Retired
  • AKA Daniel
« Reply #3 on: October 25, 2008, 08:39:12 AM »
My pleasure  :-)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: October 25, 2008, 09:16:31 AM »
So let’s break down how AutoCAD ObjectARX interprets atoms and lists. ObjectARX sees lisp types as a resbuf, essentially a container that has a type code and a value. I.e. (5000 . “Gile”)  where the type code describes the type of the value. In C#, the basic type for getting and returning values to lisp is called a TypedValue, it’s essentially the same as ObjectARX’s resbuf as it contains a type code and an Object.
So a real number would look like
(LispDataType.Double  .  3.33333)
And a String
(LispDataType.Text .  “Gile”)
Keep in mind that C# knows nothing of parenthesis or the dot in the dotted pair.
When returning custom lists to lisp, you must explicitly construct them
I.e
(LispDataType.ListBegin . null)
(LispDataType.DottedPair . null)
(LispDataType.ListEnd  , null)
Would return (3.3333 . “Gile”)  to lisp
A ResultBuffer in C# is a container for TypedValue types. Its unmanaged type is a resbuf or resbuf chain
an example
      //++-- A new buffer to return
      ResultBuffer buf = new ResultBuffer();
      //make a list
      buf.Add(new TypedValue((int)LispDataType.ListBegin));
      buf.Add(new TypedValue((int)LispDataType.Double , 3.3333));
      buf.Add(new TypedValue((int)LispDataType.DottedPair));
      buf.Add(new TypedValue((int)LispDataType.Text, "Gile"));
      buf.Add(new TypedValue((int)LispDataType.ListEnd));
      return buf;
Sorry, I haven’t had my coffee yet, so I’m probably not doing this well
« Last Edit: October 25, 2008, 09:38:01 AM by Daniel »
It's Alive!
  • Retired
  • AKA Daniel
« Reply #5 on: October 25, 2008, 09:27:34 AM »
You can print out the TypedValues to see their codes and values
//(lisp2 '(1 2 3 4 5 6 7))
    [LispFunction("Lisp2")]
    public static Object Lisp2(ResultBuffer resBuf)
      if (resBuf == null)
        return false;
      Editor ed = AcAp.Application.DocumentManager.MdiActiveDocument.Editor;
      //I like to convert the ResultBuffer to a List<>
      List<TypedValue> list = new List<TypedValue>(resBuf.AsArray());
      foreach (TypedValue atom in list)
        ed.WriteMessage("\n{0}", atom);
      return true;
It's Alive!
  • Retired
  • AKA Daniel
« Reply #6 on: October 25, 2008, 09:51:05 AM »
I have attached some of the lisp stuff I was playing with a while back, maybe you can get something out of it.  :mrgreen:
   //(test1 1 1 "Hello" "Dude")
    [LispFunction("test1")]
    public static ResultBuffer test1(ResultBuffer args)
      ResultBuffer retList = new ResultBuffer();
      try
        Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
        if (args == null)
          retList.AddErr("Null Argument");
          return retList;
        if (args.GetCount() == 0)
          retList.AddErr("To Few Arguments");
          return retList;
        Func<TypedValue, bool>
          filter = x => x.TypeCode == (int)LispDataType.Text;
        var rlist = args.Where(filter);
        foreach (var e in rlist)
          retList.AddString(e.Value.ToString());
        if (retList.GetCount() == 0)
          retList.AddNil();
          return retList;
      catch (System.Exception ex)
        retList.AddErr(ex.Message);
      return retList;
    //(test2 "s" "a" "s" "a" "ad")
    [LispFunction("test2")]
    public static ResultBuffer test2(ResultBuffer args)
      try
        if (args == null)
          return retList;
          return retList;
        var query = from f in args
                    where f == new TypedValue((int)LispDataType.Text, "a")
                    select f;
        foreach (var e in query)
          retList.AddString((string)e.Value);
          retList.AddNil();
          return retList;
      return retList;
« Last Edit: October 25, 2008, 10:05:05 AM by Daniel »
gile
  • Marseille, France
« Reply #7 on: October 25, 2008, 06:57:00 PM »
One more time thank you Daniel, I have to study all this :-o
Spike Wilbury
« Reply #8 on: October 25, 2008, 07:11:20 PM »
great for you.... welcome :)
« Reply #9 on: October 25, 2008, 07:14:18 PM »
:roll: :|
