Author Topic: Ashade  (Read 13301 times)
One Shot
Ashade
« on: September 24, 2004, 03:32:32 PM »
Does anyone have a lisp routine that will kill the Ashade layer?
Ashade
« Reply #1 on: September 24, 2004, 04:06:48 PM »
Try this ....
(command "erase" (ssget "x" '((8 . "ASHADE"))))
CADaver
Ashade
« Reply #2 on: September 24, 2004, 05:22:08 PM »
Quote from: Keith
Try this ....
Add a purge to that:
                "-purge" "la" "ashade" "n"
                "-purge" "bl" "ave_*" "n"
And bye-bye
(editted) make that a -purge
David Bethel
Ashade
« Reply #3 on: September 24, 2004, 06:26:01 PM »
ASHADE layer can be and is usually locked as well, so you need to unlock it.  -David
R12 Dos - A2K
One Shot
Ashade
« Reply #4 on: September 28, 2004, 02:59:17 PM »
Can't get it to work.  Is there anything else that goes with it?
Ashade
« Reply #5 on: September 28, 2004, 03:47:47 PM »
What is it ?
One Shot
Ashade
« Reply #6 on: September 28, 2004, 04:40:57 PM »
Quote from: Mark Thomas
What is it ?
The code that is listed above.
Ashade
« Reply #7 on: September 28, 2004, 04:47:39 PM »
What is the error you get?
Is the ASHADE layer locked? as noted above by David.
Did you try something like this;
(sslength (ssget "x" '((8 . "ASHADE"))))
One Shot
Ashade
« Reply #8 on: September 28, 2004, 04:56:48 PM »
Is there anyother coding to go with this?
Ashade
« Reply #9 on: September 28, 2004, 06:29:13 PM »
Quote from: One Shot
Nope! That's it. Have a look at C:\<AutoCAD Install>\Help\acad_dev.chm.
CADaver
Ashade
« Reply #10 on: September 28, 2004, 06:40:46 PM »
You need to be aware that layer ASHADE will return every time you issue a RENDER command
Ashade
« Reply #11 on: September 28, 2004, 08:23:06 PM »
CADaver that may indeed be the issue....
Ashade
« Reply #12 on: September 28, 2004, 08:49:42 PM »
I'm confused, what's wrong with the presence of the ashade layer, or the defpoints layer for that matter? I could be bothered if one of our users wanted either deleted; hello, bigger fish to fry.
I welcome enlightenment though, I miss the salient point more frequently than I'd like to admit.
Ashade
« Reply #13 on: September 28, 2004, 08:55:19 PM »
well.... for me it is not the issue of whether the layer should or should not be deleted, it is whether it can be. The answer of course is yes it can be and the code in this thread shows how....
I learned long ago, don't bother asking too many questions, just give the boss what he wants. In this case OneShot is the boss and I for one was merely attempting to answer the question at hand, not convolute it with more questions.
One Shot
Ashade
« Reply #14 on: September 28, 2004, 09:04:43 PM »
Quote from: Keith
I am aware that it will return when the Render command is used.  The reason that I want to delete is to ensure that no one puts anything on that layer.  I will never delete the defpoints layer.
Keith, thank you for your response.
