While searching through old programs I came across this. It uses an Excel file as a database. The original program looped through a selection set and searches for specific blocks with attributes. It then compares the attribute text to a cell in the Excel file. From there, other information from Excel is pulled and dumped into a table object in AutoCAD, creating a type of "dynamic" table.
Dim x As Integer
For x = 0 To UBound(objKeys)
[color=red]GetLightInfo[/color] UCase(objKeys(x))
objTable.InsertRows objTable.Rows, 0.59375, 1
objTable.Update
objTable.SetText objTable.Rows - 1, 0, objDict(objKeys(x))
objTable.SetText objTable.Rows - 1, 1, UCase(objKeys(x))
objTable.SetText objTable.Rows - 1, 2, strMfg
objTable.SetText objTable.Rows - 1, 3, strDesc
objTable.SetText objTable.Rows - 1, 4, strVolts
objTable.SetText objTable.Rows - 1, 5, strLamps
Next x
Option Explicit
Public cn As ADODB.Connection
Public rsT As ADODB.Recordset
Public rsC As ADODB.Recordset
Public Sub [color=red]GetLightInfo[/color](strID As String)
Dim strQuery As String
Dim rstQuery As New ADODB.Recordset
OpenExcelDatabase
strQuery = "SELECT * FROM [SCHEDULE_DATABASE$]"
rstQuery.Open strQuery, cn, adOpenKeyset, adLockReadOnly
rstQuery.Filter = "TYPE = '" & strID & "'"
Do While Not rstQuery.EOF
Debug.Print rstQuery!Type
strDesc = rstQuery!Description
strMfg = rstQuery("MFR & SERIES")
strVolts = rstQuery!VOLTS
strLamps = rstQuery!LAMPS
rstQuery.MoveNext
Loop
rstQuery.Close
CloseExcelDatabase
Private Sub OpenExcelDatabase()
Dim intTblCnt As Integer, intTblFlds As Integer
Dim strTbl As String
Dim intColCnt As Integer, intColFlds As Integer
Dim strCol As String
Dim t As Integer, c As Integer, f As Integer
Set cn = New ADODB.Connection
With cn
.Provider = "Microsoft.Jet.OLEDB.4.0"
.ConnectionString = "Data Source=" & _
"E:\Luminaire.xls;Extended Properties=Excel 8.0;"
.CursorLocation = adUseClient
.Open
End With
Private Sub CloseExcelDatabase()
On Error Resume Next
rsT.Close
rsC.Close
cn.Close
