Author Topic: corners on dashed polylines with width....  (Read 6648 times)
Alan Cullen
« on: October 16, 2008, 05:25:43 AM »
Just a quicky...if you draw a polyline with width and linestyle dashed, how do you get the corners to be neat, and not broken?
New Shooz
Re: corners on dashed polylines with width....
« Reply #1 on: October 16, 2008, 06:35:09 AM »
Instead of giving the polyline its own thickness, put them on a layer, and give the layer a lineweight ?
Alan Cullen
« Reply #2 on: October 16, 2008, 06:42:35 AM »
mmmmm...Blue, I've never used that before...wanna talk me through how that's done.
In the meantime I'll have a play with it......
Thanks, mate.
Alan Cullen
« Reply #3 on: October 16, 2008, 06:47:13 AM »
Couldn't get it to work, mate
jonesy
  • SuperMod
« Reply #4 on: October 16, 2008, 06:52:59 AM »
is it anything to do with the linetypegen?
in enabled the linetype is the same dash length and gap all the way round, but if its disabled each segment will start and end with a line.
is that what you want?
New Shooz
« Reply #5 on: October 16, 2008, 07:00:26 AM »
ok Alan, Let's presume you want a polyline that will show up on your paper as being 1mm wide, blue in colour and dashed.
I would create a layer called (for this example) Polyline, set its colour to be 5, it's linetype to Dashed, and its lineweight to be 1mm.
Set the layer created above to be the current layer, ready to be drawn upon.
Then I would draw the polyline.
That's presuming that jonesy is on the right track also.
Alan Cullen
« Reply #6 on: October 16, 2008, 07:05:16 AM »
Sorry Tracey, I've already looked at plinegen...doesn't help at all.
Alan Cullen
« Reply #7 on: October 16, 2008, 07:07:37 AM »
Blue...your possibility just draws a pline at width 0. I haven't tried to plot that to see what happens at plot time. Maybe I should do that now.....be back shortly......
New Shooz
« Reply #8 on: October 16, 2008, 07:14:55 AM »
you need to switch your LWDISPLAY to on to see its width on screen Alan
Alan Cullen
« Reply #9 on: October 16, 2008, 07:15:01 AM »
Okay.....what happens is the outside of the corners plots rounded. Could be a cui setting. But the main thing is lineweights don't comply with required thickness. In other words, a thickness of 2mm is not achieved by setting lineweight to 2mm. I'm going to have a play with the corners in the ctb file........be back again soon.....
Alan Cullen
« Reply #10 on: October 16, 2008, 07:30:07 AM »
Wow.....thank you very much Blue.
You are still a guru. I'm still really impressed with your knowledge. That worked. I'm amazed. Thank you, thank you, thank you.
Now to put all that in some form of text. It really is a complicated way to go about it.
Maybe you should suggest to Tiger it will make a great FAQ......
Once again...thanks a heap mate.
Alan Cullen
« Reply #11 on: October 16, 2008, 07:59:39 AM »
Blue, just for you mate.......
http://www.autocadeverything.com/help/showthread.php?p=15732#post15732
Go check it out........
New Shooz
« Reply #12 on: October 16, 2008, 08:02:56 AM »
Woohooo, I'm famous; didn't know I was called LCD tho  :lmao:
Alan Cullen
« Reply #13 on: October 16, 2008, 08:05:37 AM »
Hey...it's been a long time...so I forgot...so shoot me...no, don't do that.......
Matt__W
  • I like my water diluted.
« Reply #14 on: October 16, 2008, 08:23:08 AM »
Geez Tracey... I thought you would've posted >>this<< as a response.  :wink:
Autodesk Expert Elite
