Author Topic: Routine wanted to modifile-added missing line  (Read 2251 times)
kottok
« on: October 11, 2008, 01:21:40 AM »
i have this lisp which allows me to place result in drawing,but i want to write out to a text file with select y/n,how to do it?
 thanks!
; (c) Marker Engineering Surveying Co.
;Place CH,O/S,Easting and Northing on drawing with leader to point
(prompt "\nMarker Engineering Surveying Co.")
(defun c:chosen (/ endpt ent off offpt onpt ss sta startpt)
(defun Xmarksthespot (x y / leglen start)
(setq start (list x y)
leglen (* 0.03 (getvar "viewsize"))
(grdraw (polar start (angtof "135" 1) leglen)
(polar start (angtof "315" 1) leglen)
7)
(grdraw (polar start (angtof "45" 1) leglen)
(polar start (angtof "225" 1) leglen)
7)
(while (setq ss (ssget ":S" '((0 . "LINE,*POLYLINE,SPLINE,ARC"))))
(setq ent (ssname ss 0))
(setq startpt (vlax-curve-getstartpoint ent)
endpt (vlax-curve-getendpoint ent)
(xmarksthespot (car startpt)(cadr startpt))
(setq startptch(getreal "\nStart Point Ch="))
(setq t1 "Text Height: <default = ")
(setq t2 " >: ")
(setq t3 (getvar "textsize"))
(terpri)
(setq HT (getreal (strcat t1 (rtos t3 2 2) t2)))
(if (= HT nil)
(setq HT t3)
(command "dim" "dimtxt" ht "exit")
(command "dim" "dimasz" ht "exit")
(setq a " N ")
(setq b " E ")
(setq c "CH=")
(setq d "O/S=")
(while (setq offpt (getpoint "\nOffset point: "))
(setq onPt (vlax-curve-getclosestpointto ent offpt)
sta (vlax-curve-getdistatpoint ent onpt)
off (distance onpt offpt)
(setq ch (rtos (+ sta startptch) 2 3))
(setq off1 (rtos off 2 3))
;(setq p1 (getpoint "\nCoordinates of which point?"))
(setq e (rtos (car offpt) 2 3))
(setq n (rtos (cadr offpt) 2 3))
(setq coorde (strcat e b))
(setq coordn (strcat n a))
(setq chainage (strcat c ch))
(setq offset (strcat d off1))
(setq p2 (getpoint offpt"\nText Location:"))
(command "_leader" offpt p2 "a" chainage offset coorde coordn "")
;(princ (strcat "Station: " (rtos sta 2 2) " - Offset: " (rtos off 2 2)))
(redraw)
(prompt "\nType CHOSEN to start routine ")
original lisp
Re: Baseline Station and Offset
Thanks for the reply, I got a wonderful routine from the customization NG.
BTW, just using vanilla AutoCAD. Here is the routine I got from there, I'll
share here for the curious. This seems to work well for my needs. Thanks
all.
;;station/offset listing
(defun c:sta-off (/ endpt ent off offpt onpt ss sta startpt)
;; Marker for point location on the screen
;; Oct. 2004 by Jeff Mishler
7)
7)
2)))
(redraw)
Re: Routine wanted to modifile-added missing line
« Reply #1 on: October 11, 2008, 01:45:24 AM »
Give this a try:
(defun c:chosen (/ a      b      c      ch     chainage
coorde coordn d      e      file   fn    ht
keyw message       n      off1   offset p2
startptch     t1     t2     t3     endpt  ent
    7
    7
  (initget 0 "Yes No")
  (setq keyw (getkword "\nExport results [Yes/No]: "
file (strcat (getvar 'dwgprefix)
     (vl-filename-base (getvar 'dwgname))
     "_station.csv"
    (xmarksthespot (car startpt) (cadr startpt))
    (setq startptch (getreal "\nStart Point Ch="))
    (setq t2 " >: ")
    (terpri)
    (if (= HT nil)
      (setq HT t3)
    (setq a " N ")
    (setq b " E ")
    (setq c "CH=")
    (setq d "O/S=")
      (setq p2 (getpoint offpt "\nText Location:"))
      (if (= Keyw "Yes")
  (setq fn (open file "a"))
  (write-line
    (strcat chainage "," offset "," coorde "," coordn)
    fn
  (close fn)
    (redraw)
kottok
« Reply #2 on: October 11, 2008, 04:22:16 AM »
thanks ronjonp !
« Reply #3 on: October 11, 2008, 07:13:16 AM »
Welcome to TheSwamp kottok.
« Reply #4 on: October 11, 2008, 09:03:07 AM »
