Author Topic: xref paperspace items  (Read 2372 times)
danny
« on: September 23, 2004, 10:45:29 PM »
Is it possible to xref items from paperspace.  Whenever you xref a file, it always gives the modelspace drawing.  I have revision clouds, located on paperspace, that have information (property set definitions) on them, and I would like to xref all the drawings sheets (paperspace)into one file so that I can generate a revision schedule for the project.
Xrefing paperspace items???
« Reply #1 on: September 23, 2004, 10:57:33 PM »
currently not possible...
There is a routine here somewhere that moves all PS items into MS so you can xref them... but you would have to do a search for them.
Robb
« Reply #2 on: September 24, 2004, 04:21:09 AM »
That command is CHSPACE I believe. It allows you to select items that you want moved to modelspace and allows you to select which viewport you want to use (I guess for scaling purposes). Currently I dont know of a way to xref paperspace items either.
Danny, take some time and register you babooze!
rob@DPInc.  :P
ML
« Reply #3 on: September 28, 2004, 07:18:52 PM »
How about something real simple like, Go to paperspace, tiled in paper
^C^Ccopy(or cut)clip;all;(setvar "tilemode" 1);_pasteclip;0,0;z;e;
This little macro will at least move EVERY THING from paper to Model for you effortlessly.
