hello .
i made some code
it is 1 point slice
but there is problem
if i select 1 point , that cut object , but other side is erase
i would like to remain all object without erasing
is that possible ?
(defun c:sx (/ pt1 pt2 pt3 ssolid ss1)
(setvar "cmdecho" 0 )
(setvar "osmode" 35 )
(setq small (ssget '((0 . "3DSOLID"))))
(setq sd (ssget "x" (list '(0 . "3DSOLID") (cons 410 (getvar "ctab")))))
(seiso sd small )
(setq cl1 (getvar "clayer"))
(if (= (tblsearch "layer" "section") nil) (laymake) (setvar "clayer" "section") )
(setq pt1 (getpoint "1 point : ")
pt2 ( polar pt1 0 9000000 )
pt3 (list (nth 0 pt2) (nth 1 pt2) (+ (nth 2 pt2) 9000000))
ssolid (ssget "f" (list pt1 pt2))
(command "slice" ssolid "" pt1 pt2 pt3 "b")
(setvar "clayer" cl1)
