options>>Plot/Publish page
uncheck USE OLE Appication when printing....
Good thinking, but alas it isn't checked.
I didn't think about checking there until your post.
I finally said the heck with it and just inserted it into PSpace and moved on.
Thanks anyway,
craigr
That would be because of autodesk and the stupid subscription program giving them license to NOT fix issues release after release. Say thank you to autodesk, and every customer that willing subscribes to this form of 'product development'
Rotating OLE objects
Published date: 2006-Sep-13 ID: TS1059077
Applies to:
AutoCADŽ 2009
AutoCADŽ 2008
AutoCADŽ 2007
AutoCADŽ 2006
AutoCADŽ 2005
AutoCADŽ 2004
Issue
When you tried to rotate an inserted OLE object, the object only moved around the point of displacement and the display angle did not change.
OLE objects also may not appear in rotated plot or publish output.
Solution
It is not possible to rotate an inserted OLE object or perform a rotated plot or publish operation on OLE data. In general, OLE objects have fewer modifcation options than other drawing objects.
If rotation is required, consider one of the following alternate methods for inserting external data into your drawing......
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=8057718&linkID=9240617Notice they do not even bother to change the date of the knowledge base document....they just keep adding the new version to the list of product that it DOES NOT function in....2009 wasn't even released in the year 2006!
