Author Topic: Delete Selection Set of Dynamic Blocks with Matching Attributes/Layer/VisState  (Read 3381 times)
Matt__W
  • I like my water diluted.
I've got some code I've been working on (see below) that allows the user to select a dynamic block.  The program then grabs the blocks effective name, visibility state, attributes (if any) and layer.  From there I was hoping to create a selection set of blocks that have those same characteristics.  Now, what I've got so far will create a selection set of blocks with the same layer name.  I was wondering if there's a way to use filters (similar to below) to set the visibility state, effective name and attribute rather than looping through all of the objects within the selection set and testing if they have any of these characteristics.
FilterType(0) = 0
FilterData(0) = "Insert"
FilterType(1) = 8
FilterData(1) = strBlkLayerName
Set sset = vbdPowerSet("BlockCountBySelection")
sset.Select acSelectionSetAll, , , FilterType, FilterData
Complete code...
Option Explicit
Public Sub Main()
    Dim sset As AcadSelectionSet
    Dim Entity As AcadEntity
    Dim Point As Variant
    Dim objDynBlk As AcadBlockReference
    Dim vDynProps As Variant
    Dim oDynProp As AcadDynamicBlockReferenceProperty
    Dim i As Integer
    Dim strVisState As String
    Dim varAtts() As AcadAttributeReference
    Dim intAttVal As Integer
    Dim strAttValue As String
    Dim retVal As Long
    Dim strDynBlkName As String
    Dim FilterType(1) As Integer
    Dim FilterData(1) As Variant
    Dim strBlkLayerName As String
    ThisDrawing.Utility.GetEntity Entity, Point, "Select a block: "
    If TypeOf Entity Is AcadBlockReference Then
        Set objDynBlk = Entity
        If objDynBlk.IsDynamicBlock = True Then
            strBlkLayerName = objDynBlk.Layer
            If objDynBlk.EffectiveName Like "MY_DB_*" Then
                strDynBlkName = objDynBlk.EffectiveName
                vDynProps = objDynBlk.GetDynamicBlockProperties
                For i = 0 To UBound(vDynProps)
                    Set oDynProp = vDynProps(i)
                    If oDynProp.PropertyName = "Visibility" Then
                        strVisState = oDynProp.Value
                    End If
                Next i
                If objDynBlk.HasAttributes = True Then
                    varAtts = objDynBlk.GetAttributes
                    For intAttVal = 0 To UBound(varAtts)
                        If UCase(varAtts(intAttVal).TagString) = "DATATYPE" Then
                            strAttValue = varAtts(intAttVal).TextString
                        Else
                            strAttValue = Null
                        End If
                    Next intAttVal
                End If
                retVal = MsgBox("Do you want to continue and delete all blocks with the following characteristics?" & vbCrLf & _
                            vbCrLf & _
                            "Block Name: " & strDynBlkName & vbCrLf & _
                            "Visibility State: " & strVisState & vbCrLf & _
                            "Attribute: " & strAttValue & vbCrLf & _
                            "Layer Name: " & strBlkLayerName, vbQuestion + vbYesNo, "Continue...")
                Select Case retVal
                    Case Is = vbNo
                        Exit Sub
                    Case Is = vbYes
                        FilterType(0) = 0
                        FilterType(1) = 8
                End Select
            Else
                MsgBox "NOT a dynamic block!"
            End If
        End If
    Else
        MsgBox "The selected object is NOT a block."
    End If
End Sub
Public Function vbdPowerSet(strName As String) As AcadSelectionSet
    Dim objSelSet As AcadSelectionSet
    Dim objSelCol As AcadSelectionSets
    Set objSelCol = ThisDrawing.SelectionSets
    For Each objSelSet In objSelCol
        If objSelSet.Name = strName Then
            objSelSet.Delete
            Exit For
        End If
    Next
    Set objSelSet = ThisDrawing.SelectionSets.Add(strName)
    Set vbdPowerSet = objSelSet
End Function
Autodesk Expert Elite
About the only thing you can do to trim down the SS would be to filter for the BlockName AND "*UXXX" named blocks. This would eliminate all other non-Dynamic blocks and Dynamic blocks whose dynamic properties have not been altered.
Matt__W
I was kinda afraid my options would be very limited.  Thanks, Jeff.
Matt__W
Okay... quick question.  Code 2 will give me the annonymous block name, what would I use to get the effectivename?  Is there a number for that?  If so, what is it?  :?
(2 . "*U256")
No, there is no DXF code for the Effectivename. So your Filter must get ALL Anonymous blocks, then check the Effectivename as you loop through the SS.
So a portion of the filter will be:
2
strDynBlkName & ",'*U*"
note the single quote before the first *.
Matt__W
Exactly what I thought... just needed the confirmation.  *kicks at ground*
