BTW, the easiest way to see the order of appended objects, is to fire up ARXDBG and enable it's dbase reactors, then insert a block for instance..........
Since you brought up the ObjectArx SDK, can you explain how I would "fire up" something out of that package? I downloaded it a while back and noticed that most everything in there is c++, I don't have a full Visual Studio package to compile those projects, I know there's ways to compile C# or VB.net projects outside of Visual Studio, but how do I do a C++ project? And should I?
Thanks,
Viktor.
