Author Topic: Leadering Text...  (Read 15745 times)
Re: Leadering Text...
« Reply #15 on: September 29, 2008, 09:09:10 PM »
Good one Andrea.
Works in 2000 but the ghosting is very slow. The cursor flashes and you have to pause the mouse for a second or two before the vectors are drawn.  The Move Reactor does not work if you click & hold to move text. It also doesn't work if you move the leader parts.
PS I don't mean to be critical, just indicating areas where he routine can be improved.
Here is another dynamic leader
http://www.theswamp.org/index.php?topic=7089.0
« Last Edit: September 29, 2008, 09:19:26 PM by CAB »
Andrea
« Reply #16 on: September 29, 2008, 10:29:52 PM »
Ok, i'll take a look on how i can improve this.
Good Catch...didn't think about it.
but...
I use
(list "MOVE" "STRETCH" "GRIP_MOVE" "GRIP_STRETCH")for the reactor list command,....and don't know realy what is the command for Dragging only.
anyone know ?
Don't worry,..I take all comments and suggestions.
Thanks,..  ;-)
Keep smile...
GDF
« Reply #17 on: September 30, 2008, 09:44:46 AM »
Andrea
I give up, why is it working forsome but not all? Still cannot get it to work. I have tried everything.
Right now I am using 2008.
Gary
Andrea
« Reply #18 on: September 30, 2008, 10:13:45 AM »
Andrea
Gary
Sorry Garry,..
bad to hear that..
some questions..
do you load some 3rd party software ? like Inroads, autoTurn..etc. ?
maybe there is some conflict ?   :|
Keep smile...
GDF
« Reply #19 on: September 30, 2008, 10:24:48 AM »
No, we use our own inhouse routines...
Could be some varable setting.
Gary
Andrea
« Reply #20 on: September 30, 2008, 11:12:48 AM »
Gary
maybe..
but i'm curious to know..
did you made the test by loading only the TLEADER2 application ?
Keep smile...
GDF
« Reply #21 on: September 30, 2008, 11:21:35 AM »
Andrea
I unloaded ALL routines and restarted AutoCAD...and I still get "nil" at the command line.
Gary
Andrea
« Reply #22 on: September 30, 2008, 11:42:55 AM »
Andrea
Gary
OK Thanks Gary,..
nil = is the result when you have no text in the current drawing.
I don't know realy where to start..
I'll take a look, make more tests and let you know when get new release.
andrea.
Keep smile...
