Author Topic: DCL dialog change active window question  (Read 2846 times)
alanjt
  • Standby for witty remark...
« on: September 24, 2008, 12:00:49 PM »
with DCL, what is the coding for when your dialog pops up and you make something else your active window, it won't close (as if you pressed ok)?
Dropbox
Re: DCL dialog change active window question
« Reply #1 on: September 24, 2008, 12:04:34 PM »
That sounds like normal behavior. The dialog should not close until the user closes it.
jbuzbee
« Reply #2 on: September 24, 2008, 12:37:10 PM »
Sounds like you mean a Modal (floating) dialog.  Can't be done with DCL.
Do a search for OpenDCL
James Buzbee
Windows 8
alanjt
« Reply #3 on: September 24, 2008, 01:14:54 PM »
oops, should have proofed what i typed. i DON'T want it to close, but if i have it open and switch to a different window it will act as if i pressed ok. i want to prevent it from acting this way; i only want it to close if i click ok or hit escape. sorry guys.
Dropbox
jbuzbee
« Reply #4 on: September 24, 2008, 01:40:10 PM »
Yep, that's Modal behavior.  DCL not going to provide that fuunctionality.
James Buzbee
Windows 8
alanjt
« Reply #5 on: September 24, 2008, 01:44:34 PM »
but it's the only DCL dialog i've ever seen do this.
i'm 100% with you on how awesome odcl is, i'm working on learning it. however, this is for something very simple, 1 edit box to type in a single string and an ok button, that's it. i use it as a subroutine that i can just setq a value from it.
Dropbox
« Reply #6 on: September 24, 2008, 02:10:13 PM »
tHEN THERE IS SOMETHING ABOUT THIS DIALOG THAT IS CLOSING IT.
Darn Caps!
Are you using an OK_Cancel button? Or a button you made?
Can you post the DCL & lisp code?
alanjt
« Reply #7 on: September 24, 2008, 03:58:22 PM »
Darn Caps!
lol, for a moment there, i really thought i had upset you.
here's the code, i don't know why i didn't just post it to begin with. i didn't create this, found it floating around here and just modified it a little.
(defun GetString-dlg (title str / dcl_id fn fo)
  (setq fn (vl-filename-mktemp "" "" ".dcl"))
  (setq fo (open fn "w"))
  (setq ValueStr (strcat "value = \"" str "\";"))
  (write-line (strcat "stringdlg : dialog {
              label = \"" title "\";") fo)
  (write-line ": edit_box {
              label = \"\";
              edit_width = 30;
              key = \"stringdlg\";
              is_default = true; " fo)
  (write-line ValueStr fo)
  (write-line "}" fo)
  (write-line ": row {
              alignment   = centered;
              fixed_width = true;
               : button {
               label      = \"OK\";
               key        = \"dcl_accept\";
               width      = 10;
               allow_accept = true;
         }" fo)
   (close fo)
   (setq dcl_id (load_dialog fn))
   (new_dialog "stringdlg" dcl_id)
   (action_tile "stringdlg" "(setq str $value)(done_dialog)")
   (start_dialog)
   (unload_dialog dcl_id)
   (vl-file-delete fn)
  str
Dropbox
« Reply #8 on: September 24, 2008, 04:16:55 PM »
Allow_accept - Instead of selecting an item from the list and then the OK
button, this allows you to select by double-clicking the list item.
Change allow_accept to is_default
              label = \"\";
              edit_width = 30;
              key = \"stringdlg\";" fo)
              ;is_default = true;
  (write-line "}" fo)
              fixed_width = true;
               : button {
               label      = \"OK\";
               width      = 10;
               is_default = true;
         }" fo)
   (close fo)
   (start_dialog)
   (vl-file-delete fn)
  str
« Last Edit: September 24, 2008, 04:22:40 PM by CAB »
« Reply #9 on: September 24, 2008, 04:19:52 PM »
Another version, no Title though.
;;; FUNCTION
;;;   Use ddedit box to edit a text string.
;;; ARGUMENTS
;;;  txt = the text string
;;; USAGE
;;;  text_edit
;;; PLATFORMS
;;; 2000+
;;; AUTHOR
;;; Charles Alan Butler
;;; ab2draft@TampaBay.rr.com
;;; VERSION
;;; 1.0 Oct. 06, 2004
(defun text_edit (txt / entlist ent)
  (if (entmake
        (list
          '(0 . "TEXT")
          (cons 10 '(0 0))
          (cons 40 1)
          (cons 7 (getvar "TEXTSTYLE"))
          (cons 1 txt) ; Text String
      (setq ent (entlast))
      (command "._ddedit" ent "")
      (setq txt (cdr (assoc 1 (entget ent))))
      (entdel ent)
      txt
(defun c:test (/ newtext)
  (setq newtext (text_edit "This is a test string."))
