Author Topic: ShortCuts.lsp  (Read 9550 times)
ahankhah
Re: ShortCuts.lsp
« Reply #15 on: April 30, 2011, 04:23:05 AM »
I should imagine it would be:
(_CreateShortcut "c:\\test.lnk" "d:")
/guess
Welcome to theSwamp Ahankhah  :-)
Lee,
nice to see you here.
You are right as always.
Thank you very much.
ahankhah
Re: ShortCuts.lsp
« Reply #16 on: April 30, 2011, 04:30:40 AM »
Welcome X2  :-)
And to change the image of the link you'd need to add:
(vlax-put-property sc 'IconLocation "C:\\Windows\\System32\\shell32.dll, 9")
Where the number in red is the icon index in the dll.
ronjonp,
I appreciate your help.
ahankhah
Re: ShortCuts.lsp
« Reply #17 on: April 30, 2011, 04:40:36 AM »
Is it possible to pass a folder address to (_CreateShortcut) function as the second argument?
A quick test suggests yes, a folder as the target argument is fine. :)
Yes, One must pass folder name to he function without trailing slash:
right: (_CreateShortcut (strcat (getenv "userprofile") "\\Desktop\\Shortcut to Z.lnk")
                 "Z:")
false: (_CreateShortcut (strcat (getenv "userprofile") "\\Desktop\\Shortcut to Z.lnk")
                 "Z:\\")
« Last Edit: April 30, 2011, 04:50:51 AM by ahankhah »
Re: ShortCuts.lsp
« Reply #18 on: April 30, 2011, 05:34:20 PM »
Welcome X2  :-)
ronjonp,
No prob :)
Pepe
Re: ShortCuts.lsp
« Reply #19 on: May 01, 2011, 08:34:27 AM »
Hi!
One simple (I hope) question:
Using these methods would I be able to get which Autocad's shorcutmenu has been used for last time? I mean EDIT, etc...
Many months ago I asked for a way to get it in order to know which menu item has been clicked in a GRREAD loop. I'm still looking for it  .
Thanks in advance.
I can hear the wind creeping through the frozen moors... It makes me shiver...
