Author Topic: list manipulation and extraction issue, need help  (Read 2175 times)
alanjt
  • Standby for witty remark...
« on: September 19, 2008, 01:03:16 PM »
i'm having a little trouble extracting specific layers from a list of layers with information...
if i have a list of layers in this format:
("P-PAVMT,11,CONTINUOUS" "P-PAVMT-T,11,CONTINUOUS" "P-SEWER,92,PROP SEWER"
"P-SEWER-T,92,CONTINUOUS" "P-BLDG,3,CONTINUOUS" "P-BLDG-T,10,CONTINUOUS"
"P-BLDG-H,9,CONTINUOUS" "P-STORM,172,PROP STORM" "P-STORM-T,172,CONTINUOUS"
"P-MON,6,CONTINUOUS" "P-MON-T,6,CONTINUOUS" "P-CONC,10,CONTINUOUS"
"P-CONC-T,10,CONTINUOUS" "P-CONC-H,9,CONTINUOUS" "P-WALL,2,CONTINUOUS"
"P-WALL-T,10,CONTINUOUS" "P-FENCE,6,PROP FENCE" "P-FENCE-T,6,CONTINUOUS"
"P-WATER,132,PROP WATER MAIN" "P-WATER-T,132,CONTINUOUS" "P-ELEC,242,PROP
OVERHEAD UTILITIES" "P-ELEC-T,242,CONTINUOUS" "P-TELE,242,PROP OT"
"P-TELE-T,242,CONTINUOUS" "P-BNDRY,7,CONTINUOUS" "P-BNDRY-T,3,CONTINUOUS"
"P-TOPO,252,HIDDEN2" "P-TOPO-H,242,HIDDEN2" "P-ELEC_B,242,PROP BE"
"P-ELEC_B-T,242,CONTINUOUS" "P-RW,6,PHANTOM2" "P-RW-T,6,CONTINUOUS"
"P-STRIP,9,CONTINUOUS" "P-STRIP-T,9,CONTINUOUS" "P-MISC,10,CONTINUOUS"
"P-MISC-T,10,CONTINUOUS" "P-POOL,172,CONTINUOUS" "P-POOL-T,172,CONTINUOUS"
"P-DECK,11,CONTINUOUS" "P-DECK-T,11,CONTINUOUS" "P-CANOPY,2,HIDDEN4"
"P-CANOPY-T,10,CONTINUOUS" "P-SIGN,10,CONTINUOUS" "P-SIGN-T,10,CONTINUOUS"
"P-TREES,8,HIDDEN2" "P-RIPRAP,10,CONTINUOUS" "P-RIPRAP-T,10,CONTINUOUS"
"P-FO,242,PROP FIBER OPTIC" "P-FO-T,242,CONTINUOUS" "P-GAS,32,PROP GAS MAIN"
"P-GAP-T,32,CONTINUOUS" "P-LOT,7,CONTINUOUS" "P-CL,2,CENTER2"
"P-ROADNAME,4,CONTINUOUS")
and i'm trying to extract out only the matching layers using a filtering subroutine:
  (defun ApplyFilter (wcfilter Lst / result err)
    (if (= wcfilter "*")
      Lst
        (foreach bn Lst
            ((vl-catch-all-error-p
               (setq matchFlag (vl-catch-all-apply 'wcmatch (list bn wcfilter)))
             (setq err t)
            (matchFlag
             (setq result (cons bn result))
        (reverse result)
why is it that if i (Applyfilter "P-SEWER,*" LIST) it will return ("P-SEWER,92,PROP SEWER" "P-SEWER-T,92,CONTINUOUS")? For some reason, it's ignoring the comma, which would omit a *-T, etc. layer.
any thoughts?
Dropbox
Re: list manipulation and extraction issue, need help
« Reply #1 on: September 19, 2008, 01:17:23 PM »
Quote from: Acad Help files for wcmatch
Wild-card characters
Character
 Definition
# (pound)
 Matches any single numeric digit.
@ (at)
 Matches any single alphabetic character.
. (period)
 Matches any single nonalphanumeric character.
* (asterisk)
 Matches any character sequence, including an empty one, and it can be used anywhere in the search pattern: at the beginning, middle, or end.
? (question mark)
 Matches any single character.
~ (tilde)
 If it is the first character in the pattern, it matches anything except the pattern.
 Matches any one of the characters enclosed.
 Matches any single character not enclosed.
– (hyphen)
 Used inside brackets to specify a range for a single character.
, (comma)
 Separates two patterns.
` (reverse quote)
 Escapes special characters (reads next character literally).
« Reply #2 on: September 19, 2008, 01:20:04 PM »
Not sure I understand, but try --
(Applyfilter "P-SEWER`,*" thelist)
PS: Don't use LIST as a variable name.
« Reply #3 on: September 19, 2008, 01:21:16 PM »
What the? I didn't see Tim's response before I posted and didn't get the "someone posted before you" warning.
Weird.
« Reply #4 on: September 19, 2008, 01:23:50 PM »
Weird.
And I beat you by ~3 minutes.  I ninja!
« Reply #5 on: September 19, 2008, 01:25:56 PM »
lolz!
alanjt
« Reply #6 on: September 19, 2008, 01:37:38 PM »
BEAUTIFUL!!
thank you guys so much!
i didn't/don't, i just typed LIST to represent the list. thanks for the tip though. :)
Dropbox
« Reply #7 on: September 19, 2008, 07:34:02 PM »
Alan I assume you got the answer  but I'll state it anyway.
(Applyfilter "P-SEWER*" TheList) ; get anything that starts with "P-SEWER"
(Applyfilter "~*-T" TheList) ; get anything that does not end with "-T"
Revised code to work with this revised list.
      Lst
        (foreach bn Lst
               (setq matchFlag (vl-catch-all-apply 'wcmatch (list (car bn) wcfilter)))
             (setq err t)
            (matchFlag
        (reverse result)
(defun c:test (/ thelist)
  (setq thelist
         '(("P-PAVMT" 11 "CONTINUOUS")
           ("P-PAVMT-T" 11 "CONTINUOUS")
           ("P-SEWER" 92 "PROP SEWER")
           ("P-SEWER-T" 92 "CONTINUOUS")
           ("P-BLDG" 3 "CONTINUOUS")
           ("P-BLDG-T" 10 "CONTINUOUS")
           ("P-BLDG-H" 9 "CONTINUOUS")
           ("P-STORM" 172 "PROP STORM")
           ("P-STORM-T" 172 "CONTINUOUS")
           ("P-MON" 6 "CONTINUOUS")
           ("P-MON-T" 6 "CONTINUOUS")
           ("P-CONC" 10 "CONTINUOUS")
           ("P-CONC-T" 10 "CONTINUOUS")
           ("P-CONC-H" 9 "CONTINUOUS")
           ("P-WALL" 2 "CONTINUOUS")
           ("P-WALL-T" 10 "CONTINUOUS")
           ("P-FENCE" 6 "PROP FENCE")
           ("P-FENCE-T" 6 "CONTINUOUS")
           ("P-WATER" 132 "PROP WATER MAIN")
           ("P-WATER-T" 132 "CONTINUOUS")
           ("P-ELEC" 242 "PROP OVERHEAD UTILITIES")
           ("P-ELEC-T" 242 "CONTINUOUS")
           ("P-TELE" 242 "PROP OT")
           ("P-TELE-T" 242 "CONTINUOUS")
           ("P-BNDRY" 7 "CONTINUOUS")
           ("P-BNDRY-T" 3 "CONTINUOUS")
           ("P-TOPO" 252 "HIDDEN2")
           ("P-TOPO-H" 242 "HIDDEN2")
           ("P-ELEC_B" 242 "PROP BE")
           ("P-ELEC_B-T" 242 "CONTINUOUS")
           ("P-RW" 6 "PHANTOM2")
           ("P-RW-T" 6 "CONTINUOUS")
           ("P-STRIP" 9 "CONTINUOUS")
           ("P-STRIP-T" 9 "CONTINUOUS")
           ("P-MISC" 10 "CONTINUOUS")
           ("P-MISC-T" 10 "CONTINUOUS")
           ("P-POOL" 172 "CONTINUOUS")
           ("P-POOL-T" 172 "CONTINUOUS")
           ("P-DECK" 11 "CONTINUOUS")
           ("P-DECK-T" 11 "CONTINUOUS")
           ("P-CANOPY" 2 "HIDDEN4")
           ("P-CANOPY-T" 10 "CONTINUOUS")
           ("P-SIGN" 10 "CONTINUOUS")
           ("P-SIGN-T" 10 "CONTINUOUS")
           ("P-TREES" 8 "HIDDEN2")
           ("P-RIPRAP" 10 "CONTINUOUS")
           ("P-RIPRAP-T" 10 "CONTINUOUS")
           ("P-FO" 242 "PROP FIBER OPTIC")
           ("P-FO-T" 242 "CONTINUOUS")
           ("P-GAS" 32 "PROP GAS MAIN")
           ("P-GAP-T" 32 "CONTINUOUS")
           ("P-LOT" 7 "CONTINUOUS")
           ("P-CL" 2 "CENTER2")
           ("P-ROADNAME" 4 "CONTINUOUS")
  (setq ret (Applyfilter "~*-T" TheList))
alanjt
« Reply #8 on: September 19, 2008, 09:36:49 PM »
very cool, thanks alan. yeah, i got everything working (for now). it also gave me the idea to run a check after to remove all that that do not match the required format.
(setq layer_list (ApplyFilter "*`,*`,*" layer_list))i know my questions aren't over, i'm still working on the dcl portion (other post).
thanks guys.
Dropbox
VovKa
  • Ukraine
« Reply #9 on: September 20, 2008, 05:54:04 AM »
this one is more simple
    Lst
    (vl-remove-if-not
      (function (lambda (e) (wcmatch (car e) wcfilter)))
      Lst
« Reply #10 on: September 20, 2008, 11:13:59 AM »
To me this one is more flexible:
(defun _WCMatchList ( lst pattern ignorecase )
    (   (lambda ( foo pattern ) (vl-remove-if-not 'foo lst))
        (if ignorecase
            (lambda (x) (wcmatch (strcase x) pattern))
            (lambda (x) (wcmatch x pattern))
        (if ignorecase (strcase pattern) pattern)
Given there's no guarantee all the strings are the same case it affords the caller the ability to ignore or honor the case.
Sample data with mixed case strings.
(setq lst
        "P-CL,2,CENTER2"
        "P-ELEC,242,PROPOVERHEAD UTILITIES"
        "p-pavmt,11,continuous"
        "p-pavmt-t,11,continuous"
        "p-pool,172,continuous"
        "p-pool-t,172,continuous"
        "p-riprap,10,continuous"
        "p-riprap-t,10,continuous"
        "p-roadname,4,continuous"
        "p-rw,6,phantom2"
        "p-rw-t,6,continuous"
        "p-sewer,92,prop sewer"
        "p-sewer-t,92,continuous"
        "p-sign,10,continuous"
        "p-sign-t,10,continuous"
        "p-storm,172,prop storm"
        "p-storm-t,172,continuous"
        "p-strip,9,continuous"
        "p-strip-t,9,continuous"
        "p-tele,242,prop ot"
        "p-tele-t,242,continuous"
        "p-topo,252,hidden2"
        "p-topo-h,242,hidden2"
        "p-trees,8,hidden2"
        "p-wall,2,continuous"
        "p-wall-t,10,continuous"
        "p-water,132,prop water main"
        "p-water-t,132,continuous"
Honor the case:
(_WCMatchList lst "P-*`,*`,CONTINUOUS" nil)
(_WCMatchList lst "p-*`,*`,continuous" nil)
Ignore the case.
(_WCMatchList lst "p-*`,*`,continuous" t)
Mileages vary, this is mine.
Cheers.
alanjt
« Reply #11 on: September 20, 2008, 08:47:59 PM »
very nice mike, i didn't even think about case considerations.
Dropbox
