Author Topic: I need help creating sheet subsets in ADT/MEP  (Read 2903 times)
commodore
« on: September 19, 2008, 06:52:07 AM »
I'm using MEP2008 and I'm trying to get a subset created in the "Sheets" folder of my main sheetset.
I can get a subset created in the root just fine with the attached code, but I can't figure out what I need to do to get it to create the subset down in the "Sheets" folder so I would end up with ProjPath\Sheets\Newsubset\*.dwgs
Can someone tell me how to tell vb to create new subsets under my "Sheets" folder (as ADT/MEP stores sheet drawings), instead of the plain vanilla AutoCAD location of directly inside the root sheetset?
Code attached.
Matt__W
  • I like my water diluted.
Re: I need help creating sheet subsets in ADT/MEP
« Reply #1 on: September 19, 2008, 08:54:04 AM »
You looking for something like this?
Autodesk Expert Elite
commodore
« Reply #2 on: September 19, 2008, 12:28:28 PM »
Could be. I'm a newbie to VBA so let me soak it in and I'll let you know.
Thanks for replying.
commodore
« Reply #3 on: September 19, 2008, 04:26:15 PM »
Ok, I've looked this over and unless I've missed the boat (entirely possible!) I don't think this is what I was after.
Looks like this creates in the root project directory and places the drawings in the subsets in them just like vanilla Acad.
You appear to have ADT/MEP, so let me try to explain better.
I'm using the Project Navigator and my project path is O:\Comm_Custom\enu\test proj folder\9A677-A. By default the PN places sub-directories in this project folder, one of those being Sheets for storing... well.. Sheets.
When you create a subset by right clicking on the root sheetset and select new and get to the subset properties dialog one one of the options is a check box to "Create folders relative to parent subset storage location", if you select this check box the new subset will be created, and a new directory gets created under "Sheets" that any new sheet drawings in that subset will be stored in. So if were to manually create a new subset called "Submittal 8.5x11" with the "Create folders relative to parent subset storage location" selected I would end up with a new folder O:\Comm_Custom\enu\test proj folder\9A677-A\Sheets\Submittal 8.5x11 that any sheets added to that subset will now be stored in.
I cant figure out how to get this done with VB, get the folder (subset) created and have the PN recognize it to dump sheet drawing into.
commodore
« Reply #4 on: September 24, 2008, 07:48:43 AM »
Do you have any other ideas? (see above).
Matt__W
« Reply #5 on: September 24, 2008, 09:20:14 AM »
Sounds like you're on your own with this one.  I'm not sure how PN works and/or reads the info.  I would assume there's another XML in there somewhere.
