Author Topic: Display file path in a popup_list  (Read 8071 times)
psuchewinner
« on: September 18, 2008, 02:15:19 PM »
I want to be able to select a drawing file in my dialog box but i dont want to use the "getfiled" (or is it findfile, idunno). Kinda like the "open" dialog.  I dont want the distraction of having another dialog box opening.  I want it all right in one dialog box.  Can this be done?
GDF
Re: Display file path in a popup_list
« Reply #1 on: September 18, 2008, 02:29:17 PM »
Try this one out...it may give you some ideals.
http://www.theswamp.org/index.php?topic=9518.0
The code for activate is by Peter Jamtgaard.
psuchewinner
« Reply #2 on: September 19, 2008, 07:35:53 AM »
Thanks Gary, I dig into it.
psuchewinner
« Reply #3 on: October 02, 2008, 12:00:53 PM »
still not "getting it".
I want to be able to make a "LOOK IN:" drop down list.  So I can select a directory and store that path in a variable.  I dont want to use (Getfiled) becasue it open up another dialog box and I dont want to do it that way.
TimSpangler
  • CAD Naked!!
« Reply #4 on: October 02, 2008, 12:05:31 PM »
ACA 2015 - Windows 7 Pro
psuchewinner
« Reply #5 on: October 02, 2008, 01:03:06 PM »
Let me clarify what I want to do.
I want to be able to browse for a file (without using "getfiled") and retrieve some xdata from it.
The dialog that I posted will have some extra stuff in it but I want to be able to get all of settings and info from 1 dialog box.
Is it possible?
What I need is some code to show a directory tree in the popup_list or list_box and the code to store it.
That is as far as I've gotten.  I wanted to start with the hardest part first.  Getting the xdata and everything else is the easy part.
Gary posted some code (above) but I cant get it to do what I want.
GDF
« Reply #6 on: October 02, 2008, 01:33:41 PM »
( (lambda ( / path)
    ;; Example:
    ;; build a list of files in user selected path
    ;; By: Se7en
    ;;         4/12/2007 12:03:11 PM
    (defun BrowseForFolder ( / sh folder folderobject result)
      ;; From: Tony Tanzillo
      ;; Newsgroups: autodesk.autocad.customization
      ;; (setq folder (BrowseForFolder))
      (setq sh
            (vla-getInterfaceObject
              (vlax-get-acad-object) "Shell.Application"))
      (setq folder
            (vlax-invoke-method sh 'BrowseForFolder 0 "" 0))
      (vlax-release-object sh)
      (if folder
          (setq folderobject (vlax-get-property folder 'Self))
          (setq result (vlax-get-property FolderObject 'Path))
          (vlax-release-object folder)
          (vlax-release-object FolderObject)
          result
    (if (null (setq path (BrowseForFolder)))
      ;; just in case you didnt specify a path
      nil
      (vl-directory-files path "*.dwg" 1))) )
psuchewinner
« Reply #7 on: October 02, 2008, 01:55:44 PM »
Can I add to this dialog box or inbed it into one of mine?
TimSpangler
  • CAD Naked!!
« Reply #8 on: October 02, 2008, 05:16:19 PM »
That is it for the browse for file/folder.  Doesn't doslib also have something similar?
Maybe OpenDCL.... James??
psuchewinner
« Reply #9 on: October 02, 2008, 07:27:59 PM »
Now that is COOL!  Was it created by OpenDCL or what?  Never seen a DCL file look so cool.  Very nice work.  I dont know a whole lot about it but I guess I check it out.  I'm gonna have to check out this thing called Open DCL!
Andrea
« Reply #10 on: October 02, 2008, 08:22:03 PM »
Thanks...
but was Created by the Original ObjectDCL and not OpenDCL (derivate product)
Keep smile...
psuchewinner
« Reply #11 on: October 03, 2008, 06:54:15 AM »
Where do we get ObjectDCL and how much does it cost?
TimSpangler
  • CAD Naked!!
« Reply #12 on: October 03, 2008, 07:36:45 AM »
« Reply #13 on: October 03, 2008, 07:42:59 AM »
Andrea
« Reply #14 on: October 03, 2008, 08:55:32 AM »
LOL !! you'r quick guy's to answer that hein ...isn' it ?
Opendcl = Free
Derivate product of ObjectDCL
ObjectDCL = Bug Free
www.ObjectDCL.com
Keep smile...
