Author Topic: Rename & Delete Dwg File  (Read 10444 times)
M-dub
« Reply #15 on: September 21, 2004, 02:58:38 PM »
Ok, I'm having a hard time finding out how to delete the original file....any hints?
« Reply #16 on: September 21, 2004, 03:50:29 PM »
Ok ... I will tell you but you MUST BE CAREFUL ....
There is a potential for serious consequenses if you are not.
FileSystem.Kill "DriveLetterFullPathFileNameFileExtension"
It accepts wildcards "*" and "?" to specify multiple files.
For example ... this will delete ALL files in the root folder, so please don't try it ...
FileSystem.Kill "C:\\*.*"
M-dub
« Reply #17 on: September 21, 2004, 03:53:46 PM »
Cheers...
If all goes as planned, there should be no errors.  Fingers are always crossed though.
« Reply #18 on: September 21, 2004, 04:31:27 PM »
Just make sure to verify the filename BEFORE you tell it to delete...
