Author Topic: [Autocad 2009] Find/Replace borked?  (Read 2353 times)
jnieman
« on: September 15, 2008, 10:56:57 AM »
ok I'm having a brain fart I think.
I looked up wild cards and such in the help file to make sure I wasn't throwing in one I wasn't aware of, but the 'dash' is only involved when a term is in brackets [A-D] <<<< like that
So what the heck is going on here?
M-dub
Re: [Autocad 2009] Find/Replace borked?
« Reply #1 on: September 15, 2008, 11:00:33 AM »
What am I missing?  I think I misunderstood your problem.
In the drawing I have open, I've got 'TB-2' and I added a copy with brackets, '[TB-2]'.  It found both when I searched for 'TB-2'.
jnieman
« Reply #2 on: September 15, 2008, 11:04:26 AM »
those detail labels are mtext, and in the bottom it contains the text "D-SIZE SHEET SCALE..."
That's not what we normally use, we use "24x36 SCALE" so I want to replace D-SIZE SHEET with 24x36
When I use "find" to find all instances of D-SIZE SHEET it returns nothing... none...
The screenshot shows exactly what I did to search the drawing, and the window on the upper left shows the results "0 found"
« Reply #3 on: September 15, 2008, 11:13:25 AM »
what are these settings?
jnieman
« Reply #4 on: September 15, 2008, 11:20:49 AM »
Same as yours, except I had "Match Case" checked unknowingly... however, I copy/pasted the term exactly from the mtext to the find box... just to avoid any overlooked mistakes.  I unchecked 'match case'
lo-and behold... it now finds them.  Even though they were all capitalized, and I searched for all capitalized .... some reason that triggered -something-
Thanks for the tip.
M-dub
« Reply #5 on: September 15, 2008, 11:22:47 AM »
Sorry, the screenshot looks like it was resized and I couldn't quite make it out.
M-dub
« Reply #6 on: September 15, 2008, 11:24:24 AM »
Thanks for the tip.
Yes, thank-you.  I was having a very similar problem with some other software.  I'm going to see if Match Case has any affect on it.
« Reply #7 on: September 15, 2008, 11:25:54 AM »
Thanks for the tip.
I tried opening your Find Properties First    ;-)
jnieman
« Reply #8 on: September 15, 2008, 11:30:48 AM »
Thanks for the tip.
 :-D
kind of like taking a screenshot of a person's desktop, setting that image as their background, and hiding their icons...
« Reply #9 on: September 15, 2008, 11:36:38 AM »
more like suffering from CAD-o-Vision
where everything is viewed through an autocad lense
And I saw that little arrow, and just had to click it....twice to make sure cad hadn't locked up on me  :-D
