Author Topic: PDF to DWG  (Read 2761 times)
VerticalMojo
PDF to DWG
« on: September 11, 2008, 03:45:56 PM »
Is it possible to create an Autocad drawing from a pdf?
M-dub
Re: PDF to DWG
« Reply #1 on: September 11, 2008, 03:49:21 PM »
Last time I checked, it was possible, but it wasn't pretty.
Everything got broken up into tiny line segments.  The letter "S" for instance would have been mabye... 18 or 20 small lines.
rkmcswain
Re: PDF to DWG
« Reply #2 on: September 11, 2008, 04:22:35 PM »
Keeping in mind that a PDF is basically just a plot file...
Here are some suggestions:
http://rkmcswain.blogspot.com/2006/03/convert-pdf-to-dwg.html
We use PDFImport from dotsoft.com
craigr
Re: PDF to DWG
« Reply #3 on: September 11, 2008, 05:03:12 PM »
This has been my experience as well. - That being said, I have tried used the coversion when I had absolutly no other option. Another thing I have used is the Corel Trace program. It works a little better - (sometimes).
I usually try both and end up using the one that comes out the best.
craigr
vinnyg
Re: PDF to DWG
« Reply #4 on: September 17, 2008, 09:50:55 AM »
If you want to spend a couple of hundred, you might get a free trial of "PDF2CAD" first. Only good for pdf files that were made from original acad drawings to begin with and not scanned drawings.
just my 2cents
craigr
Re: PDF to DWG
« Reply #5 on: September 17, 2008, 09:54:22 AM »
just my 2cents
That is why we decided to go with Corel Trace - it doesn't rely on the .pdf being created from a dwg. When we get non-.dwg files for Floorplans, more times than not, they are created by scanning - (sometimes it looks like the fire escape plan).  :-)
craigr
Alan Cullen
Re: PDF to DWG
« Reply #6 on: September 17, 2008, 10:02:31 AM »
My 2 bobs worth....PDF does not convert to DWG...maybe if the pdf was created with Adobe you have a better chance....but I doubt it. That is what a pdf is......security.
craigr
Re: PDF to DWG
« Reply #7 on: September 17, 2008, 10:05:48 AM »
Unless you set the password in Adobe, it isn't really much security - (even then, there are pw crackers on the Net.)
With Corel, if a .pdf was created from a dwg you can save it back to a .dwg with pretty good results. I HAVE to believe there are several other programs out there that do the same.
craigr
rkmcswain
Re: PDF to DWG
« Reply #8 on: September 17, 2008, 11:57:39 AM »
Quote from: craigr
... I HAVE to believe there are several other programs out there that do the same.
Yes, there are many as I noted above. Of course you lose things like dimstyles, tablestyles, textstyles, and in most cases layers and even colors. Most notable, you lose drawing accuracy.
