Author Topic: Missing Fonts??  (Read 3676 times)
whdjr
Missing Fonts??
« on: September 09, 2008, 04:09:13 PM »
Help!!!!!!
I have a user that has a problem with his fonts changing on him.  He says he may have 4 or 5 dwgs open at the same time and when he moves something in the dwg all the fonts change to simplex.
Any idea what this could be?
The paths are correct in the dwg.  It only seems to happen after he moves something and the database gets refreshed.
Thanks,
Will
Matt__W
  • I like my water diluted.
Re: Missing Fonts??
« Reply #1 on: September 09, 2008, 04:10:31 PM »
Dumb question: Are the fonts installed (.TTF) / located in a support path (.SHX)?
What does the Text Style dialog box for those specific text styles show?  Is the font image missing?  Anything out of the ordinary?
Autodesk Expert Elite
whdjr
Re: Missing Fonts??
« Reply #2 on: September 09, 2008, 04:28:01 PM »
Most of the fonts we use are shx fonts and I have checked and they are in the folders.  It seems like everything works for a while and then it just decides they want to go missing.  When you move a piece of text or change the text they go to simplex and the preview in the style box changes as well.  The user has to restart AutoCad and everything will reset to normal.  But then in a little while things will start changing.
Re: Missing Fonts??
« Reply #3 on: September 09, 2008, 04:32:47 PM »
when you say your fonts are in folders.....are you saying that they might be path-ed to a network location?
and that this person is losing or changing his drive mapping and thus losing his fonts?
whdjr
Re: Missing Fonts??
« Reply #4 on: September 09, 2008, 04:45:13 PM »
Yes, these fonts are on a server in one folder.  He is able to access everything else on the server so I see no signs of network troubles.
Re: Missing Fonts??
« Reply #5 on: September 09, 2008, 04:46:54 PM »
can you make it happen to you on that same machine...
whdjr
Re: Missing Fonts??
« Reply #6 on: September 09, 2008, 05:07:38 PM »
It's not at specific intervals of time.  He said it happened 3 times this afternoon.
So no, I guess I couldn't unless I worked on it for a while.
Rob...
Re: Missing Fonts??
« Reply #7 on: September 09, 2008, 05:38:31 PM »
This might not help you but at my office we have to have the font installed on the local machines as well as the network.
CAD Tech
Re: Missing Fonts??
« Reply #8 on: September 09, 2008, 05:42:24 PM »
have him/her switch machines with another user for a few hours, see if the problem follows them, or attacks the replacement user too
I hate to say it.....it could be something they are doing...and just don't know it. ;-)
whdjr
Re: Missing Fonts??
« Reply #9 on: September 09, 2008, 06:02:15 PM »
That'd be kinda hard to do.  People don't like to move from their space much less have to work on someone else's computer.  Besides our profiles are not roaming so that wouldn't be too feasible.
whdjr
Re: Missing Fonts??
« Reply #10 on: September 10, 2008, 10:48:43 AM »
It happened again last night before we went home and already started again this morning.  Seems like it is about every hour.  The user told me for now he is not adding any text, but it still messes up when he prints too.
Matt__W
Re: Missing Fonts??
« Reply #11 on: September 10, 2008, 10:54:12 AM »
I assume you've done the purge/audit thing to the drawing?
craigr
Re: Missing Fonts??
« Reply #12 on: September 10, 2008, 11:04:17 AM »
It sounds like a Network problem to me. - (for what that is worth)
As suggested, copy the fonts to a local folder for a while and see if the problem goes away. At a minimum, this could eliminate the network possibility.
craigr
Re: Missing Fonts??
« Reply #13 on: September 10, 2008, 11:13:56 AM »
I think you need to take over that PC and see IF and or when it happens to you, and then you might have a better idea of the who, what, where, when, and how of the problem.
Matt__W
Re: Missing Fonts??
« Reply #14 on: September 10, 2008, 11:17:06 AM »
Better yet, just walk away and pretend it never happened.   :roll:
