Author Topic: When "/=" doesn't mean (not (equal))  (Read 2959 times)
whdjr
« on: September 20, 2004, 11:35:36 AM »
Can someone tell me why this does not work:
(setq sel (ss_get ":E:S"))
     (mapcar '(lambda (x)
(if (/= x obj)
  (ssdel x sel)
     (ssnames sel)
But this does work:
(if (not (equal x obj))
  (ssdel x sel)
     (ssnames sel)
Here is the helper function SSNAMES:
(defun ssnames (selection_set / num lst)
  (repeat (setq num (sslength selection_set))
    (setq num (1- num)
 lst (cons (ssname selection_set num) lst)
  lst
This is baffling to me.  If someone can explain this please do.
Thanks,
whdjr
« Reply #2 on: September 20, 2004, 11:48:48 AM »
So with all that being said by CAB, am I correct in the way I am using (not (equal)) in this application or is there some other way to show not equal without using "/=".
« Reply #3 on: September 20, 2004, 12:11:10 PM »
You are on the right track, but there is allways another way to write it.
           (if (eq x obj)
             (); do nothing
             (ssdel x sel)
        (ssnames sel)
             (cond ((eq x obj))((ssdel x sel))))
               (ssnames sel)
PS revised the last code
David Bethel
« Reply #4 on: September 20, 2004, 12:34:52 PM »
(eq expr1 expr2)
The eq function determines whether expr1 and expr2 are bound to the same object (by setq, for example).
From VLisp A2K help.  -David
R12 Dos - A2K
whdjr
« Reply #5 on: September 20, 2004, 01:01:07 PM »
Thanks guy for the input.
I keep codin' the way I have it.
