Author Topic: Test for 32 vs 64 bit  (Read 18210 times)
GDF
« on: September 08, 2008, 11:17:25 AM »
How would I test within a lisp routine to check for 32 vs 64 bit operaring system?
I need to load different arx files based on the test above.
Here are the two files I need to check for:
DOSLib17.arx
DOSLib17x64.arx
(defun ARCH:DOSLIBLOADER  ()
  (cond ((and (>= (distof (substr (getvar "acadver") 1 4)) 15.0)
              (< (distof (substr (getvar "acadver") 1 4)) 16.0))
         (if (not (member "doslib2k.arx" (arx)))
           (arxload (findfile (strcat ARCH#SUPF "V_15\\doslib2k.arx")))))
        ((and (>= (distof (substr (getvar "acadver") 1 4)) 16.0)
              (< (distof (substr (getvar "acadver") 1 4)) 17.0))
         (if (not (member "doslib2004.arx" (arx)))
           (arxload (findfile (strcat ARCH#SUPF "V_16\\doslib2004.arx")))))
        ((and (>= (distof (substr (getvar "acadver") 1 4)) 17.0)
              (< (distof (substr (getvar "acadver") 1 4)) 18.0))
         (if (not (member "DOSLib17.arx" (arx)))
           (arxload (findfile (strcat ARCH#SUPF "V_17\\DOSLib17.arx")))))
        ((and (>= (distof (substr (getvar "acadver") 1 4)) 18.0)
              (< (distof (substr (getvar "acadver") 1 4)) 19.0))
           (arxload (findfile (strcat ARCH#SUPF "V_18\\DOSLib17.arx")))))
  (princ))
Gary
Re: Test for 32 vs 64 bit
« Reply #1 on: September 08, 2008, 11:34:26 AM »
This isn't necessarily a foolproof method, but you could check for the existance of C:\Program Files(x86) ... on all 64 bit systems, 32bit programs are installed in the C:\Program Files(x36) folder, while 64 bit programs are installed in C:\Program Files
Spike Wilbury
« Reply #2 on: September 08, 2008, 11:39:12 AM »
Gary,
Not of much, help I know... but
If I remember right, the guys from OpenDCL, have an autolisp function for this....
VovKa
  • Ukraine
« Reply #3 on: September 08, 2008, 11:44:22 AM »
running 32bit
so i can not say for sure but you may try any of these
(vl-registry-read "HKEY_LOCAL_MACHINE\\Software\\Microsoft\\Windows NT\\CurrentVersion" "ProductName")
(getenv "PROCESSOR_ARCHITECTURE")
(getenv "OS")
« Reply #4 on: September 08, 2008, 11:56:43 AM »
Would this not work? [Not Tested]
         (if (not (or (member "DOSLib17.arx" (arx))(member "DOSLib17x64.arx" (arx))))
           (or (arxload (findfile (strcat ARCH#SUPF "V_18\\DOSLib17x64.arx")))
                (arxload (findfile (strcat ARCH#SUPF "V_18\\DOSLib17.arx"))))))
<edit>
Now that I think about the situation, you may have the file present but not the resource. :oops:
« Last Edit: September 08, 2008, 01:36:51 PM by CAB »
« Reply #5 on: September 08, 2008, 11:57:32 AM »
VovKa, That is a good push in the right direction ... this should work flawlessly ... returns 32 for 32 bit and 64 for 64 bit
(if (= (getenv "PROCESSOR_ARCHITEW6432") nil)
    32
    64
mjguzik
« Reply #6 on: September 08, 2008, 12:35:59 PM »
Maybe this will provide you the information needed:
http://through-the-interface.typepad.com/through_the_interface/2007/04/loading_the_rig.html
At the bottom you will find a modified arxload function to test between 32 or 64 bit.
MJG
GDF
« Reply #7 on: September 08, 2008, 01:37:15 PM »
<edit>
Thanks Alan, this worked.
GDF
« Reply #8 on: September 08, 2008, 01:37:45 PM »
MJG
Thanks for the link, I will have to dig into it.
« Reply #9 on: September 08, 2008, 02:01:16 PM »
Gary, all versions of Windows create environment variables that determine what kind of processor architecture is running. If it is a 64 bit process you will always find PROCESSOR_ARCHITEW6432 in the environment variables, however, it will be nonexistant on 32 bit operating systems, therefore you can readily tell if the OS is running a 64 bit process or 32 bit. All windows will have the environment variable PROCESSOR_ARCHITECTURE, but you would need to verify the value against a set of unknowns.
The mere existance of PROCESSOR_ARCHITEW6432 assures you that you have a 64 bit OS running so the result would be effective.
VovKa
  • Ukraine
« Reply #10 on: September 08, 2008, 02:17:05 PM »
cool Keith™, i'll save it in my "in case of" notes
GDF
« Reply #11 on: September 08, 2008, 02:25:40 PM »
Thanks. I am playing around with and testing autocad 2009 on windows xp 64 bit on a backup machine.
So far I think autocad 09 is ___ well lets just say, I think I'll keep on 2008 for a while longer.
« Reply #12 on: September 08, 2008, 02:47:28 PM »
Do you have the 64 bit version of AutoCAD running? If not then I am not sure you can run the 64bit arx modules.
GDF
« Reply #13 on: September 08, 2008, 03:06:30 PM »
Yes I have 2009 running with all of my customization "arch program" on a 64 bit window xp machine. The DOSLib17x64.arx file loads ok...used CAB's code.
I'm looking for an acetutil.arx 64 bit version.
Everything seems to be running ok, just a very minor glitches.
My first impression is that it takes longer to open drawing files, and I don't like autocads new menu interface.
My goal is to update my "arch program" custom routines to be able to run either a 32 or 64 bit operating system.
Gary
« Last Edit: September 08, 2008, 03:09:40 PM by Gary Fowler »
« Reply #14 on: September 08, 2008, 03:09:28 PM »
Expresstools for 64bit ... hmmm ... might be hard to come by ... will the 32bit modules not load?
