I have done something like this:
[DllImport("user32.dll")]
public static extern System.IntPtr SetFocus(System.IntPtr hwnd);
// modeless form
private void onClick_InstallDoor(object sender, EventArgs e)
str_doorwidth = doorWidths_comboBox.GetItemText(doorWidths_comboBox.Items[doorWidthsIndex]);
str_doorname = doorNames_comboBox.GetItemText(doorNames_comboBox.Items[doorNamesIndex]);
str_doortype = doorTypes_comboBox.GetItemText(doorTypes_comboBox.Items[doorTypesIndex]);
str_doorframe = doorFrames_comboBox.GetItemText(doorFrames_comboBox.Items[doorFramesIndex]);
str_doorposition = doorWallPositions_comboBox.GetItemText(doorWallPositions_comboBox.Items[doorWallPositionsIndex]);
str_distanceCorner = editDistanceCorner.Text;
double d_distCorner = Converter.StringToDistance(str_distanceCorner, DistanceUnitFormat.Architectural);
editDistanceCorner.Text = Converter.DistanceToString(d_distCorner, DistanceUnitFormat.Architectural, -1);
try
// hide the dialog while doing the installation of doors
Visible = false;
doorInstaller(); // call the function
catch (System.Exception ex)
MessageBox.Show("Error: " + ex.Message); //in case there is an error, show a message
Visible = true;
SetFocus(Autodesk.AutoCAD.ApplicationServices.Application.MainWindow.Handle);
// where the called function is something like:
public static void doorInstaller()
string block_dwg = "90 degrees swing"; //default
switch (doorNamesIndex)
case 0:
break;
case 1:
block_dwg = "45 degrees swing";
break;
case 2:
block_dwg = "30 degrees swing";
break;
case 3:
block_dwg = "15 degrees swing";
break;
case 4:
block_dwg = "180 degrees swing";
break;
case 5:
block_dwg = "Pair 90 degrees swing";
break;
case 6:
block_dwg = "Pair 90 degrees double egress";
break;
case 7:
block_dwg = "Sliding";
break;
case 8:
block_dwg = "Pocket";
break;
case 9:
block_dwg = "Folding";
break;
case 10:
block_dwg = "Rolling";
break;
Editor ed = doc.Editor;
while (true)
PromptEntityResult res = ed.GetEntity("\nSelect hinge position: "); //("\n<Enter & back to dialog>/Select hinge position: ")
if (res.Status != PromptStatus.OK)
//SetFocus(Autodesk.AutoCAD.ApplicationServices.Application.MainWindow.Handle);
//acedPostCommand("");
//acedPostCommand("\003" + "\003" + "\003");
return;
using (DocumentLock doclock = ed.Document.LockDocument())
// [color=blue]more mojo..... salsa, guacamole, enchiladas, quesadillas..... goes here[/color]
tr.Commit();
}//transaction
}//docklock
}//while
