Author Topic: (challenge) count items in a list and return  (Read 10153 times)
« on: September 20, 2004, 06:39:39 AM »
Todays challenge is to return the item that appears the most times in a list along with the count. Example:
list = (12 3 43 554 3 89 987 45 3 33 4 3 12 299 33)
the item that appears the most times is '3' and it appears 4 times. Your function should return '3' and '4'.
The list _must_ contain all the same type. i.e. all integers, reals, strings etc..
« Reply #1 on: September 20, 2004, 07:40:52 AM »
And if more than one item sports the same tally return ... ?
« Reply #2 on: September 20, 2004, 08:05:20 AM »
Here's my "Haven't coded in weeks, haven't has my coffee yet" attempt ...
(defun tallymax ( lst / key pair index )
    (foreach key lst
        (setq index
            (if (setq pair (assoc key index))
                (subst
                    (cons key (1+ (cdr pair)))
                    pair
                    index
                (cons
                    (cons key 1)
                    index
    (setq key (apply 'max (mapcar 'cdr index)))
    (vl-remove-if-not
        (function (lambda (pair) (eq key (cdr pair))))
        (reverse index)
(TallyMax '(12 3 43 554 3 89 987 45 3 33 4 3 12 299 33))
returns ((3 . 4))
(TallyMax '(1 2 1 2 1 2 3))
returns ((1 . 3)(2 . 3))
Showertime ...
SMadsen
« Reply #3 on: September 20, 2004, 08:18:28 AM »
First take. Only assumes one item to appear the most times, though
(setq lst '(12 3 43 554 3 89 987 45 3 33 4 3 12 299 33))
(defun cnt (item lst num)
  (cond ((null lst) (cons item num))
        ((not (member item lst))(cons item num))
        ((cnt item (cdr (member item lst)) (1+ num)))
(defun tallyho (lst / nlst)
  (setq nlst (mapcar (function (lambda (n) (cnt n lst 0))) lst))
  (car (vl-sort nlst (function (lambda (a b)(>= (cdr a)(cdr b))))))
« Reply #4 on: September 20, 2004, 08:23:16 AM »
Quote from: MP
good question.......... I'll have to think about it. :D
« Reply #5 on: September 20, 2004, 08:24:23 AM »
Here's mine first attempt
(defun item-count (lst / cntr item tal tmp nlst)
  (setq cntr 0
        tmp 1
  ;; begin loop
  (repeat (length lst)
          (setq item (nth cntr lst)
                tal 0
          (mapcar
            '(lambda (x)
               (if (or
                     (= x item)
                     (eq x item)
                     (equal x item 0.000001); for point lists
                 (setq tal (1+ tal))
            lst
          (if (> tal tmp)
              (setq tmp tal
                    nlst (cons item tmp)
          (setq cntr (1+ cntr))
          ); end of loop
  nlst
* edited to include point lists *
David Bethel
« Reply #6 on: September 20, 2004, 08:29:43 AM »
(setq l1 '(12 43 3 554 3 89 3 987 45 33 3 4 12 299 33))
(defun irep (l / fl ol mxi)
(foreach i l
  (setq fl
    (if (not (assoc i fl))
        (cons (cons i 1) fl)
        (subst (cons i (1+ (cdr (assoc i fl)))) (assoc i fl) fl))))
(foreach p fl
  (setq ol
    (if (not (assoc (cdr p) ol))
        (cons (list (cdr p) (car p)) ol)
        (subst (append (assoc (cdr p) ol) (list (car p)))
               (assoc (cdr p) ol) ol))))
;;;Maximum Number Of Repeats
(setq mxi (apply 'max (mapcar 'car ol)))
;;;List of Numbers Used Maximum Times
(prin1 (cdr (assoc mxi ol)))
(princ (strcat " Repeats " (itoa mxi) " Times"))
(princ))
-David
R12 Dos - A2K
SMadsen
« Reply #7 on: September 20, 2004, 08:48:03 AM »
Second take. Returns all instances of identical counts
  (cond ((null lst) (cons num item))
        ((not (member item lst))(cons num item))
(defun tallyho (lst / nlst rlst m)
        m    (assoc (apply 'max (mapcar 'car nlst)) nlst))
  (mapcar (function (lambda (n)(and (= (car n) (car m))(/= (cdr n)(cdr m))
                                    (not (member n rlst))
                                    (setq rlst (cons n rlst))))) nlst)
  (cons m rlst)
(setq lst '(12 3 4 43 554 3 4 89 987 45 3 33 4 3 12 4 299 33))
(tallyho lst)
((4 . 3) (4 . 4))
(setq lst '(12 3 4 89 3 4 89 987 45 3 89 33 4 3 12 4 89 33))
(tallyho lst)
((4 . 3) (4 . 89) (4 . 4))
« Reply #8 on: September 20, 2004, 08:56:10 AM »
Funny, the thought of using 'member' never entered my mind.
Mr. Madsen, Mr. Puckett that is some beautiful code.
« Reply #9 on: September 20, 2004, 08:59:48 AM »
w00t! cool another challenge. *Cross your fingers and howe i get to use AutoCAD today! ...I need another job!*
SMadsen
« Reply #10 on: September 20, 2004, 09:23:40 AM »
Quote from: Mark Thomas
Thanks, but Mr. Madsen's is a bit clumpsy, though. Here's take three (how many attempts do we get each?) :D
(defun tallyho (lst / nlst rlst m n)
        m    (car (assoc (apply 'max (mapcar 'car nlst)) nlst)))
  (while nlst
    (setq nlst (cdr (member (setq n (assoc m nlst)) nlst)))
    (and n (not (member n rlst)) (setq rlst (cons n rlst)))
  rlst
David Bethel
« Reply #11 on: September 20, 2004, 09:42:13 AM »
Mark,
(member) is very good choice for small lists.  It gets real bogged down with large ones.  Same thing with (append).  Use (cons) & (reverse) for multiple modifies.  -David
R12 Dos - A2K
« Reply #12 on: September 20, 2004, 09:44:47 AM »
Quote from: Se7en
...Cross your fingers and hope i get to use AutoCAD today!...
Nope!? I get to use Microstation ver 7!?!? (The crapiest version. Its like using acad ver 14)  *Now wheres that darn Resum`e?!*
« Reply #13 on: September 20, 2004, 10:00:36 AM »
Ok here is my first feeble attempt ...
(defun cnt ( lst / count item maxnum )
  (setq maxnum 0)
  (mapcar '(lambda (x)
    (setq count (-(length lst)(length (vl-remove x lst))))
    (if (>= count maxnum)(setq maxnum count item (append (list x) item))))
    (vl-sort lst '<))
  (list maxnum (reverse item))
(cnt lst)
(4 (3))
(cnt lst)
(4 (3 4 89))
I have a few more ideas that I may look at later
SMadsen
« Reply #14 on: September 20, 2004, 10:14:52 AM »
Keith, I thought about that approach at first it doesn't handle lists with strings or lists or symbols.
Try these lists with it
(setq lstlst '((1 2)(2 3)(1 2)(1 2)))
(setq strlst '("a" "b" "bc" "bx" "bx"))
(setq symlst '(a b c a b bx))
