Check out the PUBLISHCOLLATE system variable.
AFAIK it's broken...sorry. Either use PUBLISHCOLLATE = 0 and combine later, or publish a multi-sheet DWF and then print that to a PDF if you really need that format.
Well, the Autodesk sollution was to use their PDF driver and it seems to work OK. Must be time to upgrade my old Adobe 7 Pro
Haven't tried yet...I'm hoping that upgrading to Adobe Acrobat Pro 9 in December will work better. Lets hope my budget gets approved!
