Ok, now that I have a basis for what you were using, is there an easy way to modify the red x coord? I'm sure that the difference in location can be determined based on the new leadergap length. I dont believe I have ever been able to successfully change the coordinates of the red x. You must have been able to in order for your code to work, could you show me the line that changes this value, then I could use it to modify the red coord and hopefully resolve the issue.
